查看: 2517|回复: 0
硫酸钡填充聚四氟乙烯粒料的制备
发表于 2018-9-24 21:54:33 |江苏| 显示全部楼层 |阅读模式
硫酸钡填充聚四氟乙烯粒料的制备
Preparation of BaSO4-Containing Polytetrafuoroethylene Granular Powder
作  者:颜录科[1,2,3] 骆睿 何苗苗 谭钧戈 刘明翀 晁敏 田野菲[1,2]
Yan Luke1,2,3,Luo Rui1,He Miaomiao1,Tan Junge1,Liu Mingchong1,Chao Min1,2,Tian Yefei1,2(1.School of Materials Science & Engineering, Chang'an University, Xi'an 710064, China;2.Institute of Polymer Materials, Chang'an University, Xi'an 710064, China; 3. Guangdong Weilinna Functional Material Co. Ltd., Foshan 528521, China)
机构地区:[1]长安大学材料科学与工程学院,西安710064 [2]长安大学高分子材料研究所,西安710064 [3]广东炜林纳功能材料有限公司,广东佛山528521
出  处:《工程塑料应用》2018年第6期5-9,共5页
Engineering Plastics Application
基  金:陕西省国际科技合作与交流计划项目(2016KW-052),中央高校基本科研业务费专项资金项目(310831151086),长安大学基础研究支持计划专项基金项目
摘  要:采用湿法造粒,分别通过球磨分散造粒和两相乳液分散造粒两种方法制备30% BaSO4填充聚四氟乙烯粒料.筛选造粒方法,确定造粒工艺,对粒料及其模压制品的性能等进行分析评价,并采用偏光显微镜(POM)和扫描电子显微镜(SEM)研究粒料的外观结构及其模压制品微观结构.结果表明,两相乳液分散造粒比球磨分散造粒效果好,更有利于生产;所得粒料具有表观密度高、平均粒径小,粒径分布窄,粉末流动性好等优点.此外,造粒可使BaSO4与PTFE混合更均匀,模压制品中产生缺陷的机会变小,力学性能提高,拉伸强度从17MPa提高到19MPa以上,断裂伸长率由320%增加到400%以上,与未造粒料相比,提高幅度均已超过10%.
30% BaSO4 filled polytetrafluoroethylene (PTFE) granular were prepared through a ball milling dispersion granulation method and a two-phase emulsion dispersion granulation method, respectively, by using wet granulation. The granulation method was screened, the granulation process was determined, the structure of particles in the granular powder was studied by polarizing optical microscope (POM) and the molded articles’microstructures were characterized and analyzed by scanning electron microscope (SEM). The results show that the two-phase emulsion dispersion granulation is the better granulating method for manufacture; the granular powder obtained has a large bulk density, a small average particle size, a narrow particle size distribution and superior powder flowability. The granulation can make BaSO4 dispersed more homogeneously in PTFE and reduce many defects in molded articles, also the tensile strength increases from 17 MPa to over 19 MPa, and the elongation at break increases from 320% to over 400%, the increase is more than 10% compared with the ungranulated material.
关 键 词:聚四氟乙烯 硫酸钡 造粒 模压制品 拉伸强度
分 类 号:TQ327.3[化学工程—合成树脂塑料工业]
硫酸钡填充聚四氟乙烯粒料的制备.rar
1.55 MB, 下载次数: 0
售价: 2 氟币  [记录]  [购买]
硫酸钡填充聚四氟乙烯粒料的制备
GMT+8, 2026-7-14 21:28 , Processed in 0.026614 second(s), 11 queries , Redis On.
