查看: 2181|回复: 0
全无油往复压缩机用碳纤维增强聚四氟乙烯密封材料的性...
发表于 2018-9-26 19:44:21 |江苏| 显示全部楼层 |阅读模式
全无油往复压缩机用碳纤维增强聚四氟乙烯密封材料的性能研究  被引量:1
Study on Properties of Carbon Fiber Reinforced PTFE Sealing Material Applied in Non-lubricated Reciprocating Compressor
作  者:杨家义 杨博峰 李香 沈宗沼 刘杰 鲍军
YANG Jia- yi,YANG Bo- feng,LI Xiang,SHEN Zong- zhao,LIU Jie,BAO Jun(Hefei General Machinery Research Institute, State Key Laboratory of Compressor Technology,Hefei Provincial Laboratory of Compressor Technology, Anhui Key Laboratory of General Mechanical Composite Technology,Hefei 230031,China)
机构地区:合肥通用机械研究院压缩机技术国家重点实验室合肥压缩机技术省级实验室通用机械复合材料技术安徽省重点实验室,安徽合肥230031
出  处:《流体机械》2017年第3期6-10,共5页
Fluid Machinery
基  金:安徽省科技攻关计划项目(1604a0902174)
摘  要:随着全无油往复压缩机排气压力的不断升高,普通配方增强聚四氟乙烯密封材料无法满足使用寿命要求。碳纤维增强聚四氟乙烯密封材料具有更加优异的耐磨性、自润滑性和力学性能。本文选用不同类型的直线型碳纤维采用模压法制备了碳纤维增强聚四氟乙烯密封材料,并对其断面形态、表面硬度、弯曲性能、摩擦磨损性能等进行了测试研究,结果表明:采用高强度、低颗粒度含量的CF-1碳纤维制得的1~#密封材料具有最佳的综合力学性能;采用低强度、低长径比的CF-3碳纤维制得的3^#密封材料具有最高的表面硬度和弯曲强度。
The general formula PTFE sealing material could not meet the requirements of service life,with the increasing of the exhaust pressure of non-lubricated reciprocating compressor. Carbon fiber reinforced PTFE sealing material had excellent wear resistance,self lubrication and mechanical properties. Different types of linear type carbon fiber reinforced PTFE sealing material were prepared by molding method. The fracture morphology,surface hardness,bending properties and tribological properties of PTFE/CF sealing material were studied. The results showed that 1~#material made by CF-1 had the best comprehensive mechanical property,and 3~#material made by CF-3 had the highest surface hardness and bend strength.
关 键 词:全无油往复压缩机 碳纤维 聚四氟乙烯 密封材料 性能研究
分 类 号:TH45[机械工程—机械制造及自动化] TB743[一般工业技术—材料科学与工程;一般工业技术—真空技术]
全无油往复压缩机用碳纤维增强聚四氟乙烯密封材料的性能研究.part1.rar.rar
2 MB, 下载次数: 1
售价: 2 氟币  [记录]
全无油往复压缩机用碳纤维增强聚四氟乙烯密封材料的性能研究.part2.rar.rar
1.43 MB, 下载次数: 2
GMT+8, 2026-7-14 21:28 , Processed in 0.027207 second(s), 11 queries , Redis On.
