查看: 2257|回复: 0
芳砜纶纤维/聚四氟乙烯复合材料的性能
发表于 2018-9-26 19:45:58 |江苏| 显示全部楼层 |阅读模式
芳砜纶纤维/聚四氟乙烯复合材料的性能
Properties of polysulfonamide fiber (PSAF)/ polytetrafluoroethylene (PTFE) composites
作  者:刘立起 王旭 谢旺 俞鸣明 方琳 李红 杨敏 肖依 任慕苏 孙晋良
LIU Liqi, WANG Xu, XIE Wang, YANG Min, XIAO Yi, (Research Center for Composite Materials YU Mingming, FANG Lin, LI Hong REN Musu, SUN Jinliang Shanghai University, Shanghai 200072, China)
机构地区:上海大学复合材料研究中心,上海200072
出  处:《上海大学学报:自然科学版》2017年第2期185-191,共7页
Journal of Shanghai University(Natural Science)
基  金:科技部对俄合作资助项目(2014DFR50460);上海市青年教师培养资助项目(37011015209)
摘  要:采用热压工艺制备芳砜纶纤维(polysulfonamide fiber,PSAF)/聚四氟乙烯(polytetrafluoroethylene,PTFE)复合材料,然后采用热重分析仪(thermal gravimetric analyzer,TGA)、差示扫描量热(diferential scanning calorimetry,DSC)法、X射线衍射(X—ray diffraction,XRD)、傅里叶转换红外(F0urier transform infrared,FTIR)、热场发射扫描式电子显微镜(thermal field scanning electron microscope,TFSEM)等方法研究了PSAF对所制备复合材料的力学性能、热稳定性、结构和微观形貌等的影响.研究结果表明,PSAF的加入提高了复合材料的力学性能,使其具有优异的热稳定性能.适量的PSAF较好地分散在PTFE基体中,PSAF与PTFE基体的界面结合较好,且同时存在物理与化学结合.
Polysulfonamide fiber (PSAF)/polytetrafluoroethylene (PTFE) composites were prepared by hot pressing process. The effect of PSAF on material mechanical properties, thermal stability, structure and morphology was studied with thermal gravimetric ana- lyzer (TGA), differential scanning calorimetry (DSC), X-ray diffraction (XRD), Fourier transform infrared (FTIR), and thermal field scanning electron microscope (TFSEM). The results show that PSAF can improve mechanical properties of the composite materials, and the composites have good thermal stability. A moderate amount of PSAF can be well dispersed in the PTFE matrix. Bonding of the PSAF and PTFE matrix interracial is good, and there is a physical adhesion.
关 键 词:芳砜纶纤维(polysulfonamide fiber PSAF) 聚四氟乙烯(polytetrafluoroethylene PTFE) 力学性能 热稳定性 结构表征
分 类 号:TB332[一般工业技术—材料科学与工程]
芳砜纶纤维/聚四氟乙烯复合材料的性能.rar
576.47 KB, 下载次数: 0
售价: 2 氟币  [记录]  [购买]
芳砜纶纤维/聚四氟乙烯复合材料的性能
GMT+8, 2026-7-14 21:27 , Processed in 0.021015 second(s), 11 queries , Redis On.
