查看: 2331|回复: 0
再生PTFE微粉改性聚四氟乙烯的摩擦性能研究
发表于 2018-9-26 19:50:51 |江苏| 显示全部楼层 |阅读模式
Study on Friction and Wear Resistance Properties of PTFE Filled with Regenerated Micropowders
作  者:周生泰 戴旭阳 周金亮 黎晨 聂云
Zhou Shengtai , Dai Xuyang , Zhou Jinliang , Li Chen , Nie Yun ( Cyg Electronics (shangh) Co., Ltd, Shanghai 201502, China)
机构地区:上海长园电子材料有限公司,上海201802
出  处:《山东化工》2017年第14期107-109,共3页
Shandong Chemical Industry
摘  要:制备了一系列不同组成的再生PTFE微粉填充聚四氟乙烯的混合物,对材料的力学、摩擦性能进行了研究。结果表明,PTFE微粉(细粉)在加入5~7份时,复合材料的力学和耐磨损性能最好,PTFE微粉(粗粉)不利于材料的外观和力学性能。微观形态研究发现,细粉与PTFE树脂的相容性较好,粗粉的相容性较差。
A series of PTFE compounds filled by regenerated PTFE micropowders were produced. The mechanical properties and friction performance were studied. It was found that compounds performed well on mechanical and friction properties when contents of PTFE micropowders (fine powders) were 5 ~ 7 phr, but go against when filled by coarse powders. It was investigated using SEM that fine powders had good compatibility with PTFE resin, but coarse powders had inferior compatibility with PTFE resin.
关 键 词:PTFE微粉 PTFE 分散树脂 摩擦 磨损 聚四氟乙烯
分 类 号:TQ342.711[化学工程—化纤工业]
再生PTFE微粉改性聚四氟乙烯的摩擦性能研究.rar
642 KB, 下载次数: 0
售价: 2 氟币  [记录]  [购买]
GMT+8, 2026-7-14 21:30 , Processed in 0.019672 second(s), 11 queries , Redis On.
