查看: 3557|回复: 0
聚四氟乙烯/玻璃纤维涂覆膜材的制备及性能
发表于 2018-9-28 18:25:40 |江苏| 显示全部楼层 |阅读模式
Preparation and properties of poly (tetra-fluoroethylene)/woven glass fibric membrane structural materials
作  者:周应学[1] 周玉善 韩成成[1] 王耀武[3] 龚正红
ZHOU Yingxue1 ,ZHOU Yushan2 , HAN Chengcheng1 ,WANG Yaowu3 ,GONG Zhenghong1 (1.School of Textile and Materials, Xi'an Polytechnic University, Xi'an 710048,China; 2.Quality Control Department, Shaanxi Huatek Fiberglass Materials Group Co. Ltd,Xianyang 710072 Shaanxi, China &Cooperative Innovational Center, Xi;an Polytechnic University, Xi'an 710048,China)
机构地区:[1]西安工程大学纺织与材料学院,陕西西安710048 [2]陕西华特集团质量部,陕西咸阳710072 [3]西安工程大学协同创新中心,陕西西安710048
出  处:《西安工程大学学报》2017年第2期157-165,共9页
Journal of Xi an University of Engineering Science and Technology
基  金:陕西省产业用纺织品协同创新中心项目(2015ZX-11);陕西省教育厅专项(16JK1324);陕西省大学生创新基金资助项目(1682)
摘  要:将玻璃纤维基布经预处理和偶联改性,然后浸渍聚四氟乙烯(PTFE)乳液,烧结制备玻璃布/PTFE结构膜材料,研究偶联剂类型和多浸渍PTFE后烧结及反复浸渍-烧结工艺对膜性能的影响.由全衰减反射-傅里叶红外光谱(ATR—FTIR)和场发射扫描电镜(FE—SEM)研究膜的结构和形貌,通过接触角测定膜的疏水性能,并由热重分析测定结构膜的热稳定性.机械强度测定结构表明膜材料可以满足使用要求.
Woven glass fibric/poly(tetra-fluoroethylene) (PTFE) membrane structural materials were prepared through pre-impurity removal, modification with silane coupling agents, and then sintered prior to dip coating with PTFE emulsion. The effects on properties for resulting membrane were investigated in type of silane coupling agents, processes of coating and sintering. Attenuated total reflectance Fourier transform infrared spectroscopy (ATR-FTIR) and field emission scanning electron microscopy (FE-SEM) were used to confirm the structure and morphology of membrane. The hydrophobilic property was tested through contact angle and thermal stability of membrane was also studied by thermogravimetric analysis. The membrane meets the requirement of application through the mechanical strength testing.
关 键 词:玻璃纤维布 聚四氟乙烯乳液 膜结构材料 烧结
分 类 号:TB324[一般工业技术—材料科学与工程]
聚四氟乙烯_玻璃纤维涂覆膜材的制备及性能.rar
1.42 MB, 下载次数: 0
售价: 4 氟币  [记录]  [购买]
GMT+8, 2026-7-14 21:30 , Processed in 0.018751 second(s), 11 queries , Redis On.
