查看: 2839|回复: 0
聚四氟乙烯(PTFE)表面处理钢筘对玻璃纤维经纱的织造性...
发表于 2018-9-28 19:09:24 |江苏| 显示全部楼层 |阅读模式
聚四氟乙烯(PTFE)表面处理钢筘对玻璃纤维经纱的织造性能影响
Influence of Surface Treatment of Reed by PTFE on Weaving Property of Glass Fiber Warp
作  者:裴鹏英 胡雨 龚小舟
PEI Pengying , HU Yu , GONG Xiaozhou (College of textile Scienee & Engineering, Wuhan Textile University, Wuhan 430200,China)
机构地区:武汉纺织大学纺织科学与工程学院,武汉430200
出  处:《现代纺织技术》2017年第4期24-27,共4页
Advanced Textile Technology
基  金:国家青年自然科学基金项目(51502209);湖北省自然科学基金项目(2015CFB553)
摘  要:为有效减少织造打纬阶段,经纱受到钢筘的反复摩擦而产生毛羽,甚至损伤、断头等磨损,通过对普通不锈钢筘片进行聚四氟乙烯(PTFE)喷涂和烧结处理,探究织造时普通不锈钢材质与表面处理后的筘片对经纱磨损程度的影响。结果表明,经聚四氟乙烯(PTFE)烧结后的钢筘,在打纬过程中,对经纱的磨损最小。实验结果可为提升高性能纤维织物的品质起到促进作用。
In the stage of beating, warp yarns are subjected to the repeated frictions of the reed, which results in hairiness, surface damages and broken ends. To reduce these problems, researchers explored the impact of common stainless steel reed and the reed after surface treatment on the wear degree of warp yarns through PTFE spraying and sintering treatment of common stainless steel reed. At the end, it is found that the reed treated by Polytetrafluoroethylene (PTFE) brings the least wear of warp yarns in the beating process. This research promotes the quality improvement of high performance fiber fabrics.
关 键 词:钢筘 聚四氟乙烯(PTFE) 表面处理 高性能纤维 织造
分 类 号:TS103.1[轻工技术与工程—纺织工程;轻工技术与工程—纺织科学与工程]
聚四氟乙烯(PTFE)表面处理钢筘对玻璃纤维经纱的织造性能影响.rar
835.54 KB, 下载次数: 0
售价: 4 氟币  [记录]  [购买]
GMT+8, 2026-7-14 21:28 , Processed in 0.022648 second(s), 11 queries , Redis On.
