查看: 9175|回复: 0
[分享] 常用橡胶塑料的简写汇总贴
发表于 2008-7-27 14:31:36 | 显示全部楼层 |阅读模式
DOZ Dioctyl Azelate,Di-2-Ethylhexyl Azelate(DIN,ISO,IUPAC) 壬二酸二辛酯,壬二酸二(2-乙已基)酯
DPCF Diphenyl Cresyl Phosphate(ISO) 磷酸二苯甲苯酯
DPOF Diphenyl Octyl Phosphate(ISO) 磷酸二苯辛酯
DUP Diundecyl Phthalate 苯二酸十一烷酯
EC Ethyl Cellulose(GB,DIN) 乙基纤维素
ECB Ethylene Copolymer Bitumen Mixture 乙烯共聚体与沥青混合物
ECO (参见CHC,CHR,CO)Epichlorohydrin Rubber(ASTM) 氯醇橡胶
EEA Ethylene Ethylacrylate Copolymer(ISO) 乙烯/丙烯酸乙酯共聚物
ELO Epoxydized Linseed Oil(DIN,ISO) 环氧化亚麻仁油
EP Epoxy Resin(GB) 环氧树脂
E/P Ethylene Propylene Copolymer(GB,ISO) 乙烯/丙烯共聚物
EPDM (参见APT,EPT,EPTR)Ethylene Propylene Terpolymer Rubber 三元乙丙橡胶
EP-G-G Epoxy Resin Prepregnated Glassfiber Textile 玻璃纤维织物环氧预浸渍物
EP-K-L Epoxy Resin Prepregnated Carbonfiber 碳纤维环氧预浸渍物
EPM (参见AP,APK,EPR)Ethylene Propylene Rubber(ASTM,ISO) 乙丙橡胶
EPR (参见AP,APK,EPM)Ethylene Propylene Rubber(BS) 乙丙橡胶
EPS Expandable Polystyrene 可发性聚苯乙烯
EPT (参见APT,EPDM,EPTR)Ethylene Propylene Terpolymer Rubber 三元乙丙橡胶
EPTR (参见APT,EPDM,EPT)Ethylene Propylene Terpolymer Rubber(BS) 三元乙丙橡胶
E-PVC PVC Emulsions Polymerisate 聚氯乙烯乳液聚合物
E-SBR SBR Emulsions Polymerisate 丁苯橡胶乳液聚合物
ESO Epoxydized Soyabean Oil(DIN,ISO) 环氧化豆油
ETFE Ethylene Tetrafluoroethylene Copolymer(GB) 乙烯/四氟乙烯共聚物
EU (参见UE)Polyether based Polyurethane Rubber(ASTM) 聚醚型聚氨本橡胶
EVA Ethylene Vinylacetate Copolymer(DIN,ISO) 乙烯/乙酸乙烯酯共聚物
EVAC Ethylene Vinylacetate Rubber(GB) 乙烯/乙酸乙烯酯橡胶
FDAP (参见DAP)Diallyl Phthalate(Resin) 苯二酸二烯丙酯(树脂)
FEP (参见PFEP)Perluoro Ethylene Propylene Copolymer(GB,DIN,ISO) 全氟(乙烯丙烯)共聚物
FLU Viton 维通橡胶
FPM Vinylidene Fluoride Hexaflyoropropylene Rubber(ASTM) 偏氟乙烯/六氟丙烯橡胶
FRP Fiber Reinforce Plastics 纤维增强塑料
FSI Fluoro Methylsilicon Rubber(ASTM) 含氟甲基硅烷橡胶
GF (参见GFK,RP)Glassfiber Plastics 玻纤增强塑料
GF-EP Glassfiber Epoxy Plastics E玻纤环氧塑料
GFK (参见GF,RP)Glassfiber Reinforced Plastics 玻纤增强塑料
GF-PF Glassfiber Phenolic Plastics 玻纤增强酚醛塑料
GFRP Glassfiber Reinforced Plastics 玻纤增强塑料
GF-UP Glassfiber Polyester(Unsaturated) Plastics 玻纤增强聚酯塑料(不饱和)
GR-I Formerly Butyl Rubber(US) 丁基橡胶
GR-M Chloroprene Rubber(US) 氯丁橡胶
GR-N Nitril Rubber(US) 丁腈橡胶
GR-S Styrol Butadiene Rubber(US) 丁苯橡胶
GUP (参见GF-UP)GF Unsaturated Polyester Plastics 玻纤增强聚酯塑料(不饱和)
HDPE High Density Polyethylene(GB) 高密度聚乙烯
HIPS High Impact Polystyrene(GB) 耐高冲击性聚苯乙烯
HMWPE High Molecular Weight Polyethylene 高分子量聚乙烯
HR (参见Butyl,PIBI)Brtyl Rubber,Isprene Isobutylene Copolymer(ASTM) 丁基橡胶
IR Isoprene Rubber,Cis 1,4-Polyisoprene
"Synthetic Natural Rubber"(ASTM,BS) 异戊二烯橡胶
KFK Carbonfiber Reinforced Plastics(DIN) 碳纤维增强塑料
LDPE Low Density Polyethylene(GB) 低密度聚乙烯
LLDPE Linear Low Density Polyethylene 线型低密度聚乙烯
MBS Methyl Methacrylate Butadiene Styrene Copolymer 甲基丙烯酸甲酯/丁二烯/苯乙烯共聚物
MC Methyl Cellulose(GB) 甲基纤维素
MDPE Medium Density Polyethylene(GB) 中密度聚乙烯
MF Melamine Formaldehyde Rein(GB,DIN,ASTM,ISO) 三聚氰胺甲醛树脂
MOD Modacrylic Fiber 改性腈纶纤维
MPF Melamine Phenol Formaldehyde Resin(GB) 三聚氰胺酚甲醛树脂
NBR (参见PBAN)Butadiene Acrylnitrile Rubber,Nitrile Rubber(ASTM,BS) 丁腈橡胶
NC (参见CN)Nitrocellulose 硝基纤维素
NCR Nitrile Chloroprene Rubber(ASTM) 腈基氯丁橡胶
NDPE Low Pressure Polyethylene 低压法聚乙烯
NK,NR Natural Rubber(ASTM) 天然橡胶
ODP (参见DODP)Octyl Decyl Phthalate(ISO) 苯二酸辛、癸酯
OER Oil Extended Rubber 油充橡胶
PA Polyamide(GB,DIN,ASTM,ISO) 聚酰胺
PA4 Pa from Butyrolactam 尼龙4,聚丁内酰胺及纤维
PA6 Pa from Caprolactam(DIN,ISO) 尼龙6,聚已内酰胺及纤维
PA6I Pa from Hexamethylene Diamine and Isophthalacid 尼龙6I,间苯二酯六甲基二胺及纤维
PA6T Pa from Hexamethylenediamine and Terephthalicacid 尼龙6T,聚对苯二甲酰已二胺及纤维
PA66 PA from Hexamothylene diamine and Adipic acid 尼龙66,聚已二酰已二胺及纤维
PA610 PA from Hexamethylene diamine and Sebacic acid(DIN,ISO) 尼龙610,聚癸二酸已二胺及纤维
PA1010 PA from Sebacicdiamine and Sebacic acid 尼龙1010,聚癸二栈癸二胺及纤维
PA11 PA from 11 amine-Undeca acid(DIN,ISO) 尼龙11,聚氨基十一酸及纤维
PA12 PA from Lauric Lactam(DIN,ISO) 尼龙12,聚十二内酰胺及纤维
PA6/12 Mixed PA from Caprolactam and Dcdecanlactam(DIN,ISO) 尼龙612,
聚已内酰胺和聚十二内酰胺混合物及纤维
PA66/610 Mixed PA from Hexamethylene diamine Adipic acid and Sebacic acid 尼龙66/610及纤维
PAA Poly(acrylic acid)(GB) 聚丙烯酸
PAC (参见PAN,PC)Polyacrylonitrile(IUPAC) 聚丙烯腈及纤维
PAN (参见PAC,PC)Polyacrylonitrile(GB) 聚丙烯腈
PB (参见PEB)Polybutene-1(GB,DIN) 聚丁烯-1
PBAN (参见NBR)Butadiene Acrylonitrile Rubber 丁腈橡胶
PBR Pyridine Butadiene Rubber(ASTM) 丁吡橡胶
PBS (参见SBR)Butadiene Styrol Rubber 丁苯橡胶
PBT (参见PB)Polybutene-1 聚丁烯-1
PBTP (参见PTMT)Polybutylene Terephthalate(GB,DIN) 聚对苯二酸丁二醇酯
PC 1.Polycarbonate(GB,DIN,ASTM,ISO) 聚碳酸酯
2.(参见PAC,PAN)Polyacrylnitrile(usually in textile industry) 聚丙烯腈
3.Formerly:Afterchlorinated PVC 氯化聚氯乙烯
PCR Polychloroprene Rubber 氯丁橡胶
PCTFE Polychlorotrifluoroethylene(GB) 聚三氟氯乙烯
PDAP Polyethylene Phthalate(GB,ISO) 聚邻苯二酸二烯丙酯
PE Polyethylene(GB,DIN,ASTM,ISO) 聚乙烯及纤维
PEC (参见CPE)Chlorinated Polyethylene(GB,DIN) 氯化聚乙烯
PeCe (参见CPVC,PC,PVCC)After Chlorinated PVC 氯化聚氯乙烯及纤维
PEOX Poly(ethylene)(GB,ISO) 聚氧化乙烯
PES Polyester Fiber 聚酯纤维
PET (参见PETP)Polyethyleneglycol Terephthalate 聚对苯二酸乙二醇酯
PETP (参见PET)Polyethyleneglycol Terephthalate(GB,DIN,ASTM,ISO) 聚对苯二酸乙二醇酯
PF Phenol Formaldehyde Resin(GB,DIN,ASTM,ISO) 酚醛树脂
PFEP (参见FEP)Tetrafluoroethylene Hexafluoropropylene Copolymer 四氟乙烯/六氟丙烯共聚物
PI 1.Polytrans Isoprene(BS)
2.Polyimide(GB) 异戊二烯橡胶
聚酰亚胺
PIB Polyisobutylene(DIN,BS) 聚异丁烯
GMT+8, 2026-3-17 18:09 , Processed in 0.085768 second(s), 19 queries .
