查看: 1620|回复: 0
国外其他氟聚物标准
发表于 2026-3-1 19:20:54 |江苏| 显示全部楼层 |阅读模式
标准号    标准名称     英文名称
ASTM D3222-05(2010)        未改性的聚偏氟乙烯(PVDF)模压,挤出和涂覆材料        Standard Specification for Unmodified Poly(Vinylidene Fluoride) (PVDF) Molding Extrusion and Coating Materials
ASTM D6713-01(2009)        聚偏氟乙烯挤出和模压型材        Standard Specification for Extruded and Compression Molded Shapes Made from Poly(Vinylidene Fluoride) (PVDF)
ASTM D3275-08(2013)        ECTFE-氟塑料模压、挤出和涂覆材料的分类系统        Standard Classification System for E-CTFE-Fluoroplastic Molding, Extrusion, and Coating Materials
ASTM D3294-15        聚四氯乙烯树脂模压板和模压型材规范        Standard Specification for Polytetrafluoroethylene(PTFE) Resin Molded Sheetand Molded Basic Shapes
ASTM D2902-00(2013)        电绝缘用含氟聚合物树脂热收缩管规范        Standard Specification for Fluoropolymer Resin Heat-Shrinkable Tubing for Electrical Insulation
ASTM D3307-10        PFA-碳氟化合物模压及挤出材料        Standard Specification for Perfluoroalkoxy (PFA)-Fluorocarbon Resin Molding and Extrusion Materials
ASTM D6867-03(2009)        PFA管        Standard Specification for Perfluoroalkoxy (PFA)-Fluoropolymer Tubing
ASTM D5675-13        低分子量的PTFE、FEP的微粉规范        Standard Classification for Low Molecular Weight PTFE and FEP Micronized Powders
ASTM F 1545-97(2009)        钢管以及管衬内里        Standard Specification for Plastic-Lined Ferrous Metal Pipe, Fittings, and Flanges
ASTM D3595-14        聚氯三氟乙烯(PCTFE)挤出塑料薄板及薄膜        Standard Specification for Polychlorotrifluoroethylene (PCTFE) Extruded Plastic Sheet and Film
ASTM D 3144-2000        电绝缘用交联聚偏氟乙烯热收缩管的标准规范        Standard Specification for Crosslinked Poly(Vinylidene Fluoride) Heat-Shrinkable Tubing for Electrical Insulation
ASTM F 1673-2004        聚偏氟乙烯(PVDF)腐蚀性废物排放系统的标准规范        Standard Specification for Polyvinylidene Fluoride (PVDF) Corrosive Waste Drainage Systems
ASTM D 3222-2005        未改良的聚偏氟乙烯(PVDF)模制、挤压和涂覆材料的标准规范        Standard Specification for Unmodified Poly(Vinylidene Fluoride) (PVDF) Molding Extrusion and Coating Materials
ASTM D 6713-2001        由聚偏氟乙烯制成的挤制和压模制型材的标准规范        Standard Specification for Extruded and Compression Molded Shapes Made from Poly(Vinylidene Fluoride) (PVDF)
NF C93-643-229-2003        绝缘软套管.第3部分:各种型号套管的规范要求.第229活页:收缩比2:1的热缩半挠性阻燃抗液流聚偏1,1-二氟乙烯        (Flexible insulating sleeving - Part 3 : specifications requirements for individual types of sleeving - Sheet 229 : heat-shrinkable semi-flexible, polyvinylidene fluoride sleeving, flame retarded, flui)
EN 60684-3-228-1998        绝缘软管 第3部分:各种型号软管规范 活页228:热缩半刚性聚偏二氟乙烯套管 阻燃 耐流体 收缩率2:1        Flexible insulating sleeving - Part 3: Specifications for individual types of sleeving - Sheet 228: Heat-shrinkable, semi-rigid polyvinylidene fluoride sleeving, flame retarded, fluid resistant, shrink ratio 2:1 (IEC 60684-3-228:1998)
prEN ISO 15014-1998        聚偏氟乙烯挤制板 要求和试验方法        Extruded sheets of polyvinylidene fluoride (PVDF) - Requirements and test methods (ISO/DIS 15014:1998)
EN 60684-3-229-2003        绝缘软套管 第3部分:个别型号套管规范 活页229::阻燃、防水、收缩比率为2:1的热收缩半软性聚编二氟乙        Flexible insulating sleeving - Part 3: Specifications for individual types of sleeving - Sheet 229: Heat-shrinkable semi-flexible polyvinylidene fluoride sleeving, flame retarted, fluid resistant, shrink ratio 2:1 (IEC 60684-3-229:2003) / Note: Endorseme
ANSI/ASTM D5575-1994        偏二氟乙烯(VDF)与其它氟化材料共聚物的详细规范依据和系统的分类        Classification for System and Basis for Specification of Copolymers of Vinylidene Fluoride (VDF) with Other Fluorinated Materials (08.03)
ANSI/ASTM D5576-2000        与其它氟素化合材料共聚的偏二氯乙烯氟化物(VDF)大量分子聚合物规范体系统和基础分类(08.03)        Classification for System and Basis for Specification of Copolymers of Vinylidene Fluoride (VDF) with Other Fluorinated Materials (08.03)
ANSI/ASTM D3222-1999        未改性聚偏氟乙烯模塑、挤塑和涂覆材料规范        Specification for Unmodified Poly(Vinylidene Fluoride) (PVDF) Molding, Extrusion, and Coating Materials (08.03)
ANSI/ASTM F1673-2004        聚偏氟乙烯(PVDF)腐蚀性废物排放系统的规范        Specification for Polyvinylidene Fluoride (PVDF) Corrosive Waste Drainage Systems
BS ISO 10931-1-1997        工业用塑料管道系统.聚氟乙二烯(PVDF).综述        Plastics piping systems for industrial applications - Poly (vinylidene fluoride) - General
BS ISO 10931-2-1997        工业用塑料管道系统.聚氟乙二烯(PVDF).管道        Plastics piping systems for industrial applications - Poly (vinylidene fluoride) - Pipes
BS ISO 10931-3-1997        工业用聚氟乙二烯(PVDF)塑料管道系统.第3部分:配件        Plastics piping systems for industrial applications - Poly (vinylidene fluoride) - Fittings
BS ISO 4433-4-1998        热塑性塑料管.耐液体化学制品.分类.第4部分:聚偏氟乙烯管        Thermoplastics pipes - Resistance to liquid chemicals - Classification - Poly(vinylidene fluoride) (PVDF) pipes
BS EN 60684-3-229-2003        绝缘软套管.各种型号套管的规范要求.热缩半挠性阻燃抗液流收缩比2:1的聚偏二氟乙烯套管        Specification for flexible insulating sleeving - Specification requirements for individual types of sleeving - Heat-shrinkable semi-flexible, polyvinylidene fluoride sleeving, flame retarded, fluid resistant, shrink ratio 2:1 - Sheet 229: Heat-shrinkable semi-flexible, polyvinylidene fluoride sleeving, flame retarded, fluid resistant, shrink ratio 2:1
BS EN 60684-3-228-2004        绝缘软套管.各种型号软管规范.阻燃、耐流体、收缩比2:1的热收缩、半硬质聚偏二氟乙烯软套管        Flexible insulating sleeving - Specification requirements for individual types of sleeving - Heat-shrinkable, semi-rigid polyvinylidene fluoride sleeving, flame retarded, fluid resistant, shrink ratio 2:1
DIN EN 60684-3-229-2004        绝缘软套管.第3部分:各种型号套管的规范要求.活页229:收缩比2:1的半挠性阻燃抗液体聚偏氟乙烯热收缩套管        Flexible insulating sleeving - Part 3: Specifications for individual types of sleeving - Sheet 229: Heat-shrinkable semi-flexible, polyvinylidene fluoride sleeving, flame retarded, fluid resistant, shrink ratio 2:1 (IEC 60684-3-229:2003); German version EN 60684-3-229:2003
DIN EN 60684-3-228-2005        绝缘软套管.第3部分:各种型号软管规范.活页228:阻燃、耐流体、收缩比2:1的热收缩、半硬质聚偏二氟乙烯软管        Flexible insulating sleeving - Part 3: Specifications for individual types of sleeving - Sheet 228: Heat-shrinkable, semi-rigid polyvinylidene fluoride sleeving, flame retarded, fluid resistant, shrink ratio 2:1 (IEC 60684-3-228:2004); German version EN 60684-3-228:2004
DIN EN ISO 10931-2006        工业用塑料管道系统.聚偏氟乙烯(PVDF).元件和系统的规范.德文版本EN ISO 10931:2005        Plastics piping systems for industrial applications - Poly(vinylidene fluoride) (PVDF) - Specifications for components and the system (ISO 10931:2005); German version EN ISO 10931:2005
IEC 60684-3-229-2003        绝缘软套管.第3部分:各种型号套管的规范要求.第229活页:热缩半挠性阻燃抗液流收缩比2:1的聚偏二氟乙烯套管        Flexible insulating sleeving - Part 3: Specifications for individual types of sleeving; Sheet 229: Heat-shrinkable semi-flexible, polyvinylidene fluoride sleeving, flame retarded, fluid resistant, shrink ratio 2 : 1
IEC 60684-3-228-2004        绝缘软管.第3部分:各种型号软管规范.活页228:阻燃、耐流体、收缩比2:1的热收缩、半硬质聚偏二氟乙烯软管        Flexible insulating sleeving - Part 3: Specifications for individual types of sleeving - Sheet 228: Heat-shrinkable, semi-rigid polyvinylidene fluoride sleeving, flame retarded, fluid resistant, shrink ratio 2:1
ISO 4433-4-1997        热塑性塑料管 耐液体化学药品 分类 第4部分:聚偏氟乙烯(PVDF)管材        Thermoplastics pipes - Resistance to liquid chemicals - Classification - Part 4: Poly(vinylidene fluoride) (PVDF) pipes
ISO 10931-2005        工业用塑料管道系统.聚偏氟乙烯(PVDF).部件和系统的规范        Plastics piping systems for industrial applications - Poly(vinylidene fluoride) (PVDF) - Specifications for components and the system
ISO 15014-2007        塑料.聚偏氟乙烯(PVDF)挤压薄膜.要求和试验方法        Plastics - Extruded sheets of poly(vinylidene fluoride) (PVDF) - Requirements and test methods
GMT+8, 2026-7-14 19:55 , Processed in 0.018421 second(s), 5 queries , Redis On.
