查看: 2943|回复: 0
聚四氟乙烯微粉改性激光全息成像树脂的研究
发表于 2011-7-31 13:47:09 | 显示全部楼层 |阅读模式
【关键词】 聚四氟乙烯微粉; 激光全息; 成像树脂; 改性;
【英文关键词】 PTFE Micro-powder; Laser Holography; Imaging Resin; Modification;
【摘要】 将聚四氟乙烯微粉(PTFE)分散于醋酸丁酯中,取配方量的分散液对激光全息成像树脂进行共混改性。通过旋转黏度计、漆膜冲击强度测试仪、模压机研究了PTFE的加入及其加入量对树脂黏度、冲击强度以及模压效果等方面的影响。结果表明:在PTFE加入量为成像树脂质量的1%~1.5%时,激光全息成像树脂的综合性能最好。
【英文摘要】 Dispersed polytetrafluoroethylene micro-powder into the butyl acetate the formula quantity of disper sed liquid was modified with the laser holographic imaging resin.The influences of the adding of PTFE and its add quantity on the viscosity,the impact strength and moulding behavior of the resin were studied by rotating viscometer,film impact strength tester and moulding machine respectively.The results showed that the laser holographic imaging resin were of the best comprehensive performance when the add qu...
聚四氟乙烯微粉改性激光全息成像树脂的研究.pdf
264.97 KB, 下载次数: 1
售价: 1 氟币  [记录]
GMT+8, 2026-3-18 14:10 , Processed in 0.098626 second(s), 24 queries .
