查看: 3525|回复: 0
聚四氟乙烯基磁性液体的制备及在井口密封中的应用
发表于 2012-6-14 06:59:09 |江苏| 显示全部楼层 |阅读模式
Preparation and Application in Shaft Top Sealing of  Polytetrafluoroethene-based Magnetic Liquid
作  者:孙维民 樊沙沙 赵丽军 史桂梅
Sun Weimin Fan Sasa Zhao Lijun Shi Guimei (College of Science, Shenyang University of Technology, Shenyang Liaoning 110870, China)
机构地区:沈阳工业大学理学院,辽宁沈阳110870
出  处:《润滑与密封》 CA 2011年第36卷第10期 81-83页,共3页
Lubrication Engineering
基  金:辽宁省自然科学基金资助项目(2008221014)
摘  要:用电弧放电法,在30%C2H2、70%Ar的混合气氛中制备Fe-Ni合金纳米粒子。利用Fe-Ni合金纳米粒子作为磁性粒子、油酸为表面活性剂、聚四氟乙烯乳液和少量硅油、硅脂的混合液为基液制备高黏度聚四氟乙烯基磁性液体。制备的聚四氟乙烯基磁性液体在25℃时的黏度为6~30Pa·s,在85℃时的黏度为1~20Pa·s,室温下饱和磁化强度为18.26~39.66A·m^2/kg。将制备的聚四氟乙烯基磁性液体应用于油井井15密封,有效密封时间比原密封结构提高50%以上。
Fe-Ni alloy nanoparticles were prepared by arc discharge evaporating Fe-Ni alloy in 30% C2H2 and 70% Ar atmosphere. Magnetic liquid with high viscosity was prepared with Fe-Ni alloy nanoparticles as magnetic particle, oleic acid as surfactant, miscible liquids of polytetrafluoroethene and little silicone oil and silicone grease as base solution. The viscosity of magnetic liquid is 6 - 30 Pa·s at 25 ℃ and 1 - 20 Pa·s at 25 ℃. The saturation magnetization of magnetic liquid is 18.26 - 39.66 A· m^2/kg at room temperature. The magnetic liquid and sealing technology were applied to gap sealing of shaft top. The results show that efficiency of sealing is increased by over 50%.
关键词:聚四氟乙烯 磁性液体 井口密封
polytetrafluoroethene ; magnetic liquid ; seal of shaft top ;
分类号:TB743 [工业技术 > 一般工业技术 > 真空技术 > 真空材料]
全文快照:2011)10—081—3 Preparation and Application in Shaft Top Sealing of P0lytetranu0r0ethene-based M agnetic Liquid Sun Weimin Fan Sasa Zhao Lijun Shi Guimei .(College of Science,Shenyang University of Technology,Shenyang Liaoning 1 10870,China) Abstract:Fe—Ni alloy nanoparticles were prepared by arc discharge evaporating Fe—Ni alloy in 30%C2 H2 and 70%Ar atmosphere.
聚四氟乙烯基磁性液体的制备及在井口密封中的应用.pdf
201.83 KB, 下载次数: 0
GMT+8, 2026-7-15 08:01 , Processed in 0.023052 second(s), 10 queries , Redis On.
