查看: 2763|回复: 1
陶瓷填充聚四氟乙烯密封材料的制备与性能研究
发表于 2012-6-24 07:28:01 |江苏| 显示全部楼层 |阅读模式
王科 谢苏江华东理工大学机械与动力工程学院,上海200237
摘 要:采用模压烧结工艺制备了陶瓷微粒改性聚四氟乙烯(PTFE)密封材料,并对其拉伸强度、压缩回弹性能和蠕变性能做了系统的研究。结果表明,该密封材料具备较好的抗拉强度,优异的压缩回弹性能和较高的抗蠕变松弛性能,可以代替同类进口密封材料应用于食品、化工、石化、造纸和医药工业。[著者文摘]
关键词:填充 聚四氟乙烯 密封 性能
分类号: TB42[著者标引]文献标识码:A文章编号:1008-0813(2010)07-0025-04栏目信息:设计与研究
Study of the Properties of Ceramic Particles Filled PTFE Sealing MaterialWANG Ke XIE Su-jiang Institute Research of Pressure Vessel and Process Equipment, East China University of Science and Technology, Shanghai 200237, ChinaAbstract:Ceramic particles filled PTFE sealing material is developed by die pressing and sintering. The tensile strength, compressibility recovery and creep relaxation of this material are studied. The results show that this material has excellent tensile strength, fine compressibility recovery and outstanding resistance to creep relaxation, it can replace imported products used in food, chemical, petrochemical, paper and pharmaceutical industries.[著者文摘]
Key words:filled; PTFE; sealing; properties
陶瓷填充聚四氟乙烯密封材料的制备与性能研究.pdf
272.05 KB, 下载次数: 12
发表于 2012-9-17 15:51:15 |湖北| 显示全部楼层
我看看如何
GMT+8, 2026-7-15 04:04 , Processed in 0.024246 second(s), 9 queries , Redis On.
