查看: 2616|回复: 0
润滑防腐涂料的研制
发表于 2012-7-10 20:43:04 | 显示全部楼层 |阅读模式
润滑防腐涂料的研制
兰平艾 中国兵器工业第五九研究所,重庆400039
摘 要:为了提高涂层的润滑与防腐性能,研制了一种以聚脲树脂为基料,以聚四氟乙烯(PDEF)、滑爽剂(PE)、硅微粉等为主要填料的润滑防腐涂料,对涂层耐磨性、摩擦因数、附着力、防腐性能进行了测试,表明涂料不仅具有无溶剂、环保、防腐性能高的优点,还具有较低的摩擦因数。[著者文摘]
关键词:润滑 防腐 聚脲 聚四氟乙烯
分类号: TG174.46 TQ637[著者标引]文献标识码:B文章编号:1001-3660(2009)04-0078-02栏目信息:应用技术
Preparation of Lubriation Anticorrosion CoatingLAN Ping-ai No. 59 Institute of China Ordnance Industry, Chongqing 400039, ChinaAbstract:In order to improve lubriation and corrosion resistance, an lubriation anticorrosion coating was pre pared with resin as matrix material, PDEF, PE Si power as main filler. The test results of wear resistance, friction factor, adhesive force, corrosion resistance show that the coating doent containt solvent. And it not olny has environment protection performance and high corrosion resistance, but also has low wear foactor.[著者文摘]
Key wordsubriation ; Corrosion resistance ; PDEF
润滑防腐涂料的研制.pdf
262.44 KB, 下载次数: 1
润滑防腐涂料的研制
GMT+8, 2026-3-18 15:19 , Processed in 0.386879 second(s), 23 queries .
