查看: 2596|回复: 0
改善防水透湿薄膜弹性的研究
发表于 2012-7-10 20:58:04 | 显示全部楼层 |阅读模式
改善防水透湿薄膜弹性的研究
张昊 吴赞敏 刘淑梅天津工业大学纺织学院
摘 要:聚四氟乙烯(PTFE)用于防水透湿涂层越来越受到重视,但对其弹性改善方面的研究还很少。将聚氨酯(TPU)加入PTFE树脂中,用简单的方法制得了PTFE/TPU共混薄膜,以改善PTFE薄膜的弹性,并用表面扫描电镜(SEM)观察、强力及弹性测试对共混薄膜进行了分析。结果表明,改性后的硼酸能使TPU和PTFE均匀掺混,TPU在共混薄膜中的含量影响薄膜的断裂伸长率和断裂强度。共混薄膜中TPU的含量小于30%时,随着TPU/PTFE值的增大,薄膜的强力下降,弹性增强。
关键词:防水透湿薄膜 聚四氟乙烯 聚氨酯 强力 弹性
分类号: TB381文献标识码:文章编号:栏目信息:
相关文献:主题相关
Analysis on the elasticity improvement of waterproof and moisture permeable membraneZhang Hao; Wu Zanmin; Liu ShumeiCollege of Textiles; Tianjin Polytechnic University);Abstract:It is more important that the PTFE used as waterproof and moisture permeable membrane.But it is not enough working at the analysis on its elasticity improvement.This paper researched on putting TPU into PTFE resin,and using a simple process to get the mixture membranes with high elasticity.The PTFE/TPU mixture membranes were analyzed,through observation by scarring electron microscopy(SEM) and test on strength the elasticity.The result showed that the improved boric acid mingled the TPU and PTFE equally and...
Key words:waterproof and moisture permeable membrane; PTFE; TPU; strength; elasticity;
改善防水透湿薄膜弹性的研究.pdf
282.26 KB, 下载次数: 0
改善防水透湿薄膜弹性的研究
GMT+8, 2026-3-18 15:16 , Processed in 2.361364 second(s), 24 queries .
