查看: 2349|回复: 0
以植物油做膜液的支撑液膜法处理染料废水的研究
发表于 2012-7-15 14:25:11 | 显示全部楼层 |阅读模式
陈敬润 赵忠良 王磊 李靖平 张洪林辽宁石油化工大学环境与生物工程学院,辽宁抚顺113001
摘 要:以天然植物油为膜液,含聚四氟乙烯涂层的聚丙烯平板膜(PPsT)作为支撑膜,研究了支撑液膜(SLM)系统去除和回收水溶液中分散染料阳离子红4G的性能及影响因素,并确定了最佳实验条件:料液pH值11.0±0.1,脱除液:1.0g/LH2SO4,搅拌速度:350rpm.膜液:棕榈油,脱除时间:7h。去除率随料液初始浓度的增大(〉100mg/L)而增大,但通量J不变(在液膜稳定的情况下)。在最佳条件下,100mg/L的染料溶液其去除率达到94.1%。利用扫描电子显微镜(SEM)和能量弥散Z射线分析仪(EDX)对该液膜的稳定性进行了研究。结果表明:染料去除率从第1d的95.2%下降到第5d的56.3%,通量J从17.2×10^-6g/m^2·s降到8.1×10^-6g/m^2S。5d后液膜的损失量为20.5%。[著者文摘]
关键词:支撑液膜(SLM)植物油 聚四氟乙烯涂层的聚丙烯平板膜(PPsT)染料废水
分类号: X703.1[著者标引]文献标识码:A文章编号:1009-0177(2009)02-0031-06栏目信息:废水处理及回用
Bench-scale Study of Textile Wastewater Treatment Using Supported Liquid Membrane Based on Vegetable OilCHEN Jing-run, ZHAO Zhong-liang, WANG Lei, LI Jing-ping , ZHANG Hong-lin School of Erwironmental and Biological Engineering, Liaoning Shihua University, Fushun 113001, ChinaAbstract:An innovative supported liquid membrane (SLM) system and its influence factors had been investigated for removal and recovery of textile dyes red 4G from the aqueous solution using natural vegetable oils and a fiat sheet polypropylene (PP) supported teflon membrane and, the optimum condition was: membrane liquid: palm oil, pH of feed solution: 11.0±0.1, acid/base concentration in the striping solution: 1.0 g/L H2SO4, stirring rate: 350 rpm. Removal efficiency of red 4G decreased with increasing Initial dye concentrations (〉100 mg/L) but the flux was thought to be stable if the membrane liquid wasn't destroyed. Under the optimum condition,the removal efficiency of 100 mg/L dye solution reached at 94.1%. The scanning electron microscope (SEM) combined with energy dispersive X-ray (EDX) analysis were used to research the stability of the SLM. Results showed that after 5 days continuous operation the removal efficiency of dye decreased from 95.2 % at first day to 56.3 % at day 5 and flux decreased from 17.2×10^-6g/m^2s to 8.1×10^-6g/m^2s. Membrane liquid lost was about 20.5 %.[著者文摘]
Key words:SLM vegetable oil PPsT membrane textile wastewater
以植物油做膜液的支撑液膜法处理染料废水的研究.pdf
426.12 KB, 下载次数: 0
GMT+8, 2026-3-13 05:51 , Processed in 0.089778 second(s), 23 queries .
