查看: 2970|回复: 0
磨耗试验机的改造及液压系统原理研究
发表于 2012-7-15 20:58:57 | 显示全部楼层 |阅读模式
磨耗试验机的改造及液压系统原理研究
陈永贤西南交通大学机械工程研究所,四川成都610031
摘 要:聚四氟乙烯板是桥梁支座的主要组成部分,其磨耗性能试验必须利用专用试验装置才完成。利用100t四柱液压试验机为主体,进行聚四氟乙烯板磨耗试验机的改造,阐述了该磨耗试验机各种试验功能动作的实现,并分析了其液压系统原理,改造后聚四氟乙烯板磨耗试验机能够满足相关标准的实验要求.[著者文摘]
关键词:磨耗试验机 液压系统原理 聚四氟乙烯板
分类号: TH873.6[著者标引]文献标识码:A文章编号:1006-0316(2009)01-0074-03栏目信息:维修与改造
相关文献:主题相关
Reconstruction for abrasive testing machine and the research on the hydraulic systemCHEN Yong-xian Southwest Jiaotong University, Chengdu 610031, ChinaAbstractTFE plate is a major part of the bridge bearing, and it makes its abrasive tests by employing the special testing machine. This paper introduces the reconstruction for abrasive testing machine of PTFE, basing on the 100T four-pillar hydraulic machine. It formulates testing motions that the abrasive testing machine could realize and analyzes its hydraulic principle system. After the reconstruction, PTEF plate abrasive testing machine can meet the experimental requirements of test standards.[著者文摘]
Key words:abrasive testing machine; hydraulic principle system; PTFE plate
磨耗试验机的改造及液压系统原理研究.pdf
185.9 KB, 下载次数: 6
磨耗试验机的改造及液压系统原理研究
GMT+8, 2026-3-18 14:07 , Processed in 0.097471 second(s), 23 queries .
