查看: 2355|回复: 0
分析化学中物质的分离方法
发表于 2012-7-15 21:02:53 | 显示全部楼层 |阅读模式
分析化学中物质的分离方法
宋大褫 北京化工大学环境学院
摘 要:第一章 分离方法介绍 1.1高速逆流色谱高速逆流色谱(HSCCC)是由美国国家医学院YioehiroIto博士于1982年首先开始的。当仪器工作时互不相容的两相溶剂在绕成线圈的聚四氟乙烯管内具有单向性流体动力平衡性质。在聚四氟乙烯管内做高速行星运转时,如用其中一相溶剂做固定相,[第一段]
关键词:分离方法 分析化学 高速逆流色谱 聚四氟乙烯 物质 两相溶剂 平衡性质 流体动力
分类号: O65 O657.7[机标]文献标识码:文章编号:栏目信息:综述
Analytical Chemistry substances separation methodAbstract:Fatty acid synthase(FAS) is the most important enzyme in synthesis fatty in cell. FAS catalyse Ac-CoA and Mal-CoA into long chain fatty acid. To inhibit the activity of FAS, it can block and reduce the access of synthesis fatty acid and in body. At the same time, it also can increase the concentration of Mal-CoA which cause the decrease of appetite. Academe has point out that FAS is both target of treatment of cancer and obesity. But the FAS inhibitor has been discovered is very lack. Cerulenin is toxic. C75 needs very high concentration of periphery dose. EGCG has poor inhibit ability.[著者文摘]
分析化学中物质的分离方法.pdf
326.11 KB, 下载次数: 6
分析化学中物质的分离方法
GMT+8, 2026-3-18 14:10 , Processed in 0.112885 second(s), 23 queries .
