查看: 2853|回复: 0
BaSO4填充改性聚四氟乙烯复合材料的制备
发表于 2012-10-13 13:50:48 |江苏| 显示全部楼层 |阅读模式
The Preparation of PTFE Composites Filled by BaSO4
作  者:丁美平 唐玉生 党婧 寇开昌 顾军渭
DING Mei-ping, TANG Yu-sheng, DANG Jing, KOU Kai-chang, GU Jun-wei (Department of Applied Chemistry, School of Science, Northwestern Polytechnical  University, Xi' an 710072, China)
机构地区:西北工业大学理学院应用化学系,陕西西安710072
出  处:《高分子材料科学与工程》 EI CAS CSCD 2009年第25卷第3期 130-133页,共4页
Polymer Materials Science & Engineering
摘  要:采用冷压成型和烧结固化相结合的方法制备了BaSO4/PTFE复合材料,对不同用量和粒径的硫酸钡填充聚四氟乙烯复合材料性能的影响进行了研究。结果表明,BaSO4填料用量和粒径大小对复合材料的性能影响很大,当BaSO4填料粒径为44μm、质量分数为40%时,复合材料的抗磨损性能最佳,比未改性的PTFE提高了2个数量级。复合材料磨损表面的SEM分析表明,随BaSO4用量的增加,复合材料的磨损机理由粘着磨损占主导逐渐转变为磨粒磨损占主导并伴随疲劳磨损。
A method of combining cold molding with sintering was adopted to prepare BaSO4/PTFE composites. The influences of BaSO4 particles with different contents and granular size on the properties of the BaSO4/PTFE composites were investigated. The results show that the contents and granular size of BaSO4 particles greatly influence on the properties of the composites. The wear resistance ability of composites is optimal, and the corresponding wear weight loss of the composite is about 100 times lower than the nature PTFE, when the size of BaSO4 is 44 /am and the mass fraction of BaSO4 is 40 %. The SEM analysis of wear surface indicates that the wear mechanisms of composites change from main adhesion wear to abrasive wear with possible fatigue wear, with the increase of fraction of BaSO4 particles.
关 键 词:聚四氟乙烯 硫酸钡 复合材料 磨损
polytetrafluoroethylene(PTFE) BaSO4 composites wear
分 类 号:TQ325.4 [工业技术 > 化学工业 > 合成树脂与塑料工业 > 聚合类树脂及塑料]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (9篇)[1]SHI Y J, FENG X, WANG H Y, et al. The effect of surface modification on the friction and wear behavior of carbon nanofiberfilled PTFE composites[J ]. Wear, 2008, 264 ( 11 - 12) : 934-939.
[2]顾军渭 张秋禹 谢超 等.聚四氟乙烯的表面改性及粘接性能研究[J].西安石油大学学报:自然科学版,2007,22(4):79-83.
[3]LAI S Q, LIT S, LIU X J, et al. The tribological properties of PTFE filled with thermally treated nano-attapulgite [ J ]. Tribol. Int., 2006, 39(6): 541-547.
[4]TANAKA K, KAWAKAMI S. Effect of various fillers on the friction and wear of polytetrafluoroethylene-based composites [J ]. Wear, 1982, 79: 221-234.
[5]TANAKA K. Transfer of sernicrystalline polymers sliding against a smooth steel surface[J]. Wear, 1982, 75:183-199.
[6]卡茨HS 米路西凯.塑料用填料及增强剂手册[M].北京:化学工业出版社,1982.56-58.
[7]刘维民 黄春祥.填充聚四氟乙烯对尼龙6摩擦磨损性能影响的研究[J].固体润滑,:.
[8]TANAKA K. Transfer of semicrystalline polymers sliding against a srnooth steel surface[J]. Wear, 1982, 75: 183-199.
[9]BAHADUR S, TABOR D. The wear of filled PTFE[J]. Wear, 1984, 98: 1-13.
BaSO_4填充改性聚四氟乙烯复合材料的制备.pdf
1.01 MB, 下载次数: 6
售价: 1 氟币  [记录]
GMT+8, 2026-7-15 04:04 , Processed in 0.108699 second(s), 10 queries , Redis On.
