查看: 2766|回复: 0
PTFE对复合镀层摩擦特性的影响
发表于 2012-10-14 08:00:00 |江苏| 显示全部楼层 |阅读模式
PTFE对复合镀层摩擦特性的影响
Influence of PTFE on the Tribological Behavior of Composite Coatings
作  者:周细应 李卫红 徐洲
Zhou Xiying1; 2 Li Weihong2 Xu Zhou2(1.School of Materials Engineering; Shanghai University of Engineering Science; Shanghai 200336; China; 2.School of Materials Science and Engineering; Shanghai Jiaotong University; Shanghai 200030; China);
机构地区:上海工程技术大学材料工程学院 上海交通大学材料工程学院
出  处:《润滑与密封》 CAS CSCD 2008年第8期 -页,共5页
Lubrication Engineering
基  金:上海市科委纳米专项基金项目(0552nm035);; 上海市教委重点学科建设基金项目(J51402)
摘  要:研究了PTFE添加量对Ni基电刷镀PTFE复合镀层的摩擦特性和磨损机制的影响。采用扫描电镜、X射线衍射仪和能谱仪分析了摩擦前后的磨损表面的形貌、组织和成分变化。结果表明TFE添加量对复合镀层的组织和摩擦特性有较大的影响。当PTFE体积分数为3%和4%时,复合镀层的摩擦因数最小;当PTFE体积分数为2%时,复合镀层的耐磨性最好。在磨损面上富含PTFE复合层的形成和面积随PTFE添加量的变化影响了复合镀层的摩擦特性及其磨损机制。
The tribological behaviors and wear mechanism of brush electroplated Ni-PTFE composite coatings with different PTFE addition were surveyed.The worn surface,coating microstructure and the compositional changes before and after wear test were characterized using scanning electron microscopy(SEM),X-ray diffraction(XRD)and energy-dispersive analysis of X-ray(EDAX).It is found that PTFE addition has significant influence on the microstructure and tribological property of the composite coatings.The composite coat...
关 键 词:电刷镀 Ni-PTFE 复合镀层 组织 摩擦与磨损
brush electroplating Ni-PTFE composite coatings microstructure friction and wear
分 类 号:TB302.3 [工业技术 > 一般工业技术 > 工程材料学 > 工程材料一般性问题 > 工程材料试验]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (11篇)[1][1]Yating Wu,Bin Shen,Lei Liu,et al.The tribological behaviour of electroless Ni-P-Cr-SiC composite[J].Wear,2006,261 (2):201-207.
[2][2]K Krishnaveni,T S Sankara Narayanan,S K Seshadri.Electrodeposited Ni-B coatings:Formation and evaluation of hardness and wear resistance[J].Mater Chem Phys,2006,99(2):300-308.
[3][4]P Gyftou,M Stroumbouli,E A Pavlatou,et al.Tribological study of Ni matrix composite coatings containing nano and micro SiC particles[J].Electrochim Acta,2005,50(23):4544-4550.
[4][5]Li Chen,Liping Wang,Zhixiang Zeng,et al.Effect of surfactant on the electrodeposition and wear resistance of Ni-Al2O3 composite coatings[J].Mater Sci Eng A,2006,434(1):319-325.
[5][6]G Straffelini,D Colombo,A Molinari.Surface durability of electroless Ni-P composite deposits[J].Wear,1999,236(1):179-188.
[6][7]P Bercot,E Pena-Munoz,J Pagetti.Electrolytic composite Ni-PTFE coatings:an adaptation of Guglielmi's model for the phenomena of incorporation[J].Surf Coat Technol,2002,157(2):282-289.
[7][8]M Pushpavanam,N Arivalagan,N Srinivasan,et al.Electrodeposited Ni-PTFE dry lubricant coating[J].Plat Surf Finish,1996,83(3):72-76.
[8][9]Yating Wu,Hezhou Liu,Bin Shen,et al.The friction and wear of electroless Ni-P matrix with PTFE and/or SiC particles composite[J].Tribol Inter,2006,39(6):553-559.
[9][10]Weihong Li,Xiying Zhou,Zhou Xu,et al.Microstructure of Ni-polytetrafluoroethylene composite coating prepared by brush electroplating[J].Surf Coat Technol,2006,201(3):1276-1281.
[10][11]Lingzhong Dua,Binshi Xu,Shiyun Dong,et al.Study of tribological characteristics and wear mechanism of nano-particle strengthened nickel-based composite coatings under abrasive contaminant lubrication[J].Wear,2004,257(6):1058-1063.
[11][12]Zhixiang Zeng,Liping Wang,Li Chen,et al.The correlation between the hardness and tribological behaviour of electroplated chromium coatings sliding against ceramic and steel counterparts[J].Surface & Coatings Technology,2006,201(6):2282-2288.
PTFE对复合镀层摩擦特性的影响.pdf
1.68 MB, 下载次数: 0
PTFE对复合镀层摩擦特性的影响
GMT+8, 2026-7-15 02:43 , Processed in 0.019300 second(s), 11 queries , Redis On.
