查看: 2916|回复: 0
聚四氟乙烯烧结成型的制备工艺
发表于 2012-11-25 12:18:14 |江苏| 显示全部楼层 |阅读模式
聚四氟乙烯烧结成型的制备工艺
Molding and Sintering Process of PTFE Bulk Sample
CHEN Xu, HUI Su-cai (School of Chemical Eng. and Tech., Tianjin University, Tianjin 300072, China)
机构地区:天津大学化工学院,天津300072
出  处:《塑料工业》 CAS CSCD 2005年第33卷第10期 38-40页,共3页
China Plastics Industry
摘  要:对聚四氟乙烯(PTFE)进行了压制试验和烧结试验,讨论了成型压力与试件的致密度、压缩强度以及压缩模量之间的关系,且对不同烧结工艺下试件的压缩强度进行了分析,得到较合适的成型压力和烧结工艺。结果表明:咖材料的压缩强度随压制压力的升高而减小,压缩模量随压制压力的升高而增加;闻的成型压力为27.5MPa,烧结温度380℃,保温时间4h。
The tests of pressing and sintering of PTFE powder were performed, and the relationship of density, compression strength and compression modulus with molding pressing force was discussed. The compression strength was analyzed under different sintering processes, and suitable pressing force and sintering process were pre- sented. The results showed the compression strength of PTFE decreased with the increase of the molding pressing force, and the compression modulus of PTFE increased with the increase of the molding pressing force. The molding pressing force of PTFE was 27.5 MPa, sintering temperature was 380℃ and insulated hold time was 4h.
关 键 词:聚四氟乙烯 冷压成型 烧结 成型压力 压缩强度
Polytetrafluoroethylene Cold Compression Molding Sintering Molding Pressing Force Compression Strength
分 类 号:TQ325.4 [工业技术 > 化学工业 > 合成树脂与塑料工业 > 聚合类树脂及塑料]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (3篇)[1]黄锐 曾邦禄.塑料成型工艺学(第二版)[M].北京:中国轻工业出版社,1996..
[2]中国科学院兰州化学物理研究所编.填充聚四氟乙烯塑料的模压成型工艺[M].北京:石油化学工业出版社,1976..
[3]王进华.[J].有机氟化工,2000,(3):21.
聚四氟乙烯烧结成型的制备工艺.pdf
178.33 KB, 下载次数: 16
售价: 1 氟币  [记录]
聚四氟乙烯烧结成型的制备工艺
GMT+8, 2026-7-15 02:15 , Processed in 0.025371 second(s), 9 queries , Redis On.
