查看: 5344|回复: 0
聚四氟乙烯微粉预辐照接枝丙烯酸的研究
发表于 2009-4-25 15:53:20 |江苏| 显示全部楼层 |阅读模式
摘 要:采用预辐照法对聚四氟乙烯(PTFE)微粉进行接枝丙烯酸改性,以改善微粉在水溶液中的分散性。研究了丙烯酸体积分数、适量浓H2SO4的添加、阻聚剂质量浓度、反应时间等因素对接枝率的影响。结果表明,接枝率随着丙烯酸体积分数(在50%以内)增加而单调递增;适量浓H2SO4能增强阻聚剂的阻聚效果,提高接枝率;在本实验条件下,阻聚剂最佳质量浓度为0.8g/L;反应在3h后接枝率即可达饱和。当丙烯酸在PTFE微粉上的接枝率达到10%以上时,改性PTFE微粉在氢氧化钠溶液中可达到均匀分散。
关键词:预辐照 接枝 丙烯酸 聚四氟乙烯微粉
Abstract:Grafting of acrylic acid (AAc) onto the surface of PTFE micropowders was per-formed by pre-irradiation method, in order to improve their dispersion in aqueous solution. The effects of various experimental parameters on the degree of grafting (G) were separately investigated, including: volume fraction of AAc, proper addition of concentrated sulfuric acid, mass fraction of inhibitor and reaction time. The result shows that G is increasing with increment of AAc concentration below 50%, and can be enhanced by adding a proper amount of sulfuric acid. Under our experimental conditions, G reached its saturated value when the mass concentration of the inhibitor was 0.8 g/L and the reaction time was 3 h. The introduction of more than 10G of poly(acrylic acid) chain on PTFE micropowders results in the good dispersion of PTFE micropowders in aqueous NaOH solution.
Key words:pre-irradiation; grafting; acrylic acid; PTFE micropowders
作者简介:王晓兵(1982-),男,山西临猗人,硕士研究生,高分子辐射化学专业
聚四氟乙烯微粉预辐照接枝丙烯酸的研究.pdf
335.81 KB, 下载次数: 28
GMT+8, 2026-7-14 23:12 , Processed in 0.022046 second(s), 10 queries , Redis On.
