查看: 4360|回复: 0
ASTM D1710-02聚四氟乙烯(PTFE)基本型材,棒材和厚壁管材
发表于 2009-8-9 20:56:15 |江苏| 显示全部楼层 |阅读模式
Standard Specification for
Extruded and Compression Molded Polytetrafluoroethylene
(PTFE) Rod and Heavy Walled Tubing1
This standard is issued under the fixed designation D 1710; the number immediately following the designation indicates the year of
original adoption or, in the case of revision, the year of last revision. A number in parentheses indicates the year of last reapproval. A
superscript epsilon (e) indicates an editorial change since the last revision or reapproval.
ASTM D1710-02聚四氟乙烯(PTFE)基本型材,棒材和厚壁管材.pdf
64.23 KB, 下载次数: 7
售价: 1 氟币  [记录]
GMT+8, 2026-10-26 08:36 , Processed in 0.028363 second(s), 9 queries , Redis On.
