查看: 8625|回复: 0
膨体聚四氟乙烯与自体耳软骨在鼻部整形中的联合应用
发表于 2018-9-24 21:35:25 |江苏| 显示全部楼层 |阅读模式
膨体聚四氟乙烯与自体耳软骨在鼻部整形中的联合应用  被引量:3
The Application of Expanded Polytetrafluoroethylene Combined with Autologous Cartilaae in Rhinoplasty
作  者:文科[1] 虞冬梅 刘漪伦
WEN Ke1,YU Dong-mei2,LlU Yi-lun3 (1.Department of Bum & Plastic Surgery, the First Affiliated Hospital of Chengdu Medical College,Chengdu 610500,Sichuan China; 2. Department of Plastic Surgery, Ping'an Hospital of Sichuan Province,Chengdu 610000,Sichuan,China; 3. Department of Plastic Surgery, Experimental Center of Chengdu Medical College,Chengdu 610000,Sichuan,China)
机构地区:[1]成都医学院第一附属医院烧伤整形科,四川成都610000 [2]四川省平安医院整形外科,四川成都610000 [3]成都医学院实验中心整形外科,四川成都610000
出  处:《中国美容医学》2017年第3期22-24,共3页
Chinese Journal of Aesthetic Medicine
基  金:本课题受省级课题基金资助(16ZB0287),课题名称:MET-EEF耦合参与间充质干细胞促进创伤修复的机制研究
摘  要:目的:研究膨体聚四氟乙烯与自体耳软骨联合应用对鼻部综合整形的效果。方法:鼻小柱基底部做“V”形切口,行“V-Y”入路,取单侧或双侧的耳软骨联合膨体聚四氟乙烯修剪适宜后,置入鼻背筋膜间隙进行隆鼻术。结果:64例术后效果良好,鼻部延长效果明显,鼻尖低平、鼻孔外露、鼻小柱退缩、鼻头肥大、鼻翼过宽等均得到矫正。鼻延长长度为5-11mm,平均延长9mm,鼻尖突出高度为3-7mm,平均高出4mm。术后均未出现假体外露,有5例假体出现轻度偏斜,有1例出现感染,但均修复成功。结论:膨体聚四氟乙烯联合自体软骨对鼻部进行整形,可以改变外鼻形态,美观效果较好,就医者对手术满意度较高,术后并发症少,安全性好。
Objective To study the effect of combined application of ePTFE and auricular cartilage in nasal plastic surgery. Methods Nasal column base to do the "V" -shaped incision, line "V-Y" approach,taking the unilateral or bilateral ear cartilage combined with expanded polytetrafluoroethylene pruning appropriate, placed in the nasal fascia space for rhinoplasty. Results 64 cases had good postoperative effects, nasal extension effect was obvious, low nose, nostrils exposed, nasal pyramid retreat, nosal hypertrophy, and wide nose were corrected. Nasal extension length was 5-11mm, the average extension was 9mm,nose protruding height was 3-7mm, the average higher than 4mm.No postoperative prosthesis exposed,there were 5 cases of mild deviation of the prosthesis,1 case was infection, but were successfully restored. Conclusion Expanded polytetrafluoroethylene combined with autologous cartilage to shape the nose, can change the external nasal morphology and the aesthetic effect is better. Patients are highly satisfied with medical treatment of less postooerative complications and good safetv
关 键 词:膨体聚四氟乙烯 鼻中隔软骨 耳软骨 鼻部整形 假体置入 鼻成形术
分 类 号:R622[医药卫生—整形外科;医药卫生—临床医学;医药卫生—外科学]
膨体聚四氟乙烯与自体耳软骨在鼻部整形中的联合应用.rar
716.96 KB, 下载次数: 0
售价: 2 氟币  [记录]  [购买]
GMT+8, 2026-10-5 02:59 , Processed in 0.041684 second(s), 11 queries , Redis On.
