查看: 2027|回复: 0
互感器用绝缘聚四氟乙烯薄膜的研制
发表于 2018-10-1 13:55:35 |江苏| 显示全部楼层 |阅读模式
互感器用绝缘聚四氟乙烯薄膜的研制
Development of Insulating PTFE Film Used on Transformers
作  者:周飞 杨俊秋
ZHOU Fei,YANG Jun-qiu (Wuhan Institute of Shipbuilding Technology, Wuhan 430050, China)
机构地区:武汉船舶职业技术学院,湖北武汉430050
出  处:《武汉船舶职业技术学院学报》2017年第1期25-27,共3页
Journal of Wuhan Institute of Shipbuilding Technology
摘  要:介绍了高性能绝缘用聚四氟乙烯薄膜的制备,该薄膜用于互感器层间及电磁线绕组的绝缘,也可用于高温即耐热环境要求高的绝缘场合,经测试薄膜的电气强度大于160kV/mm、拉伸强度大于60MPa、薄膜材料的分解温度为385℃,各项性能指标均能满足用户的要求。
This paper introduces the development of a high-performance insulating PTFE film, which is mainly used for the interlayer adhesion of transformer and the insulation of electromagnetic winding wires, and also exhibits excellent insulating properties with high temperature. TGA test shows that the electrical strength of the film is more than 160kV/ mm and its tensile strength is greater than 60 MPa. The film's heat decomposition temperature is 385℃. All properties of the new-type film can satisfy the requirements of users.
关 键 词:互感器 聚四氟乙烯薄膜 绝缘材料
分 类 号:TM55[电气工程—电器]
互感器用绝缘聚四氟乙烯薄膜的研制.pdf
181.6 KB, 下载次数: 0
售价: 4 氟币  [记录]  [购买]
互感器用绝缘聚四氟乙烯薄膜的研制
GMT+8, 2026-8-6 05:11 , Processed in 0.019977 second(s), 10 queries , Redis On.
