查看: 2180|回复: 0
防火聚四氟乙烯软管组件的设计
发表于 2018-10-1 13:59:28 |江苏| 显示全部楼层 |阅读模式
防火聚四氟乙烯软管组件的设计
Design on Fire Proof Polytetrafluoroethylene Hose Assembly
作  者:张亮 韩立斌
ZHANG Liang, HAN Libin2 (1. Shenyang Rubber Research & Design Institute Co. , Ltd, Shenyang 110021, China;2. Air Force Military Representative Office in Shenyang Shenyang 110031)
机构地区:[1]沈阳橡胶研究设计院有限公司,辽宁沈阳110021 [2]空军驻沈阳地区军事代表局,辽宁沈阳110031
出  处:《橡胶工业》2017年第2期109-111,共3页
China Rubber Industry
摘  要:设计防火聚四氟乙烯软管组件。四氟乙烯内管由两部分组成,内层掺用一定比例的导电炭黑,而外层则为纯四氟乙烯材料;金属接头采用倒刺式与多槽式复合结构;防火设计采用聚四氟乙烯软管外覆防火硅橡胶套管的形式;扣压模具设计为八瓣式。通过优化设计,提升了软管组件耐压、耐高低温、防静电、防火等性能,能够满足不同系统的使用需求。
Fire proofing polytetrafluoroethylene(PTFE)hose assembly was designed. The inner PTFE tube consisted of two layers:the inner layer compound was filled with a certain proportion of conductive carbon black,and the outer layer was made of pure PTFE material. The metal joint had a complex construction of barbed structure and multiple groove structure. The fire proof design was a fire proof silicone jacket which covered the inner PTFE tube. The pressing die was designed with eight-valve structure. With this design,the pressure resistance,high and low temperature resistance,antistatic property,and fire proof property were excellent,and the product could meet the requirements of different systems.
关 键 词:聚四氟乙烯 软管 金属接头 扣压模具 防火性
分 类 号:TQ336.3[化学工程—橡胶工业]
防火聚四氟乙烯软管组件的设计.rar
1.02 MB, 下载次数: 0
售价: 4 氟币  [记录]  [购买]
防火聚四氟乙烯软管组件的设计
GMT+8, 2026-8-6 05:11 , Processed in 0.029013 second(s), 10 queries , Redis On.
