查看: 3040|回复: 0
聚苯酯填充聚四氟乙烯机械性能和摩擦学性能研究
发表于 2018-10-1 14:04:58 |江苏| 显示全部楼层 |阅读模式
Study on Mechanical and Tribological Properties of POB Filled PTFE Composites
作  者:张宏飞 高永操 王廷梅[3] 张新瑞[3]
ZHANG Hongfei1 GAO Yongcao2 WANG Tingmei3 ZHANG Xinrui3 (1. The Aviation Army Representation in Luoyang,Luoyang Henan 471009,China; 2. Yubei Machinery Factory, Xinxiang Henan 453003, China;3. Lanzhou Institute of Chemical Physics, Chinese Academy of Sciences, Lanzhou Gansu 730000, China)
机构地区:[1]陆航驻洛阳地区军事代表室,河南洛阳471009 [2]豫北机械厂,河南新乡453003 [3]中国科学院兰州化学物理研究所,甘肃兰州730000
出  处:《润滑与密封》2017年第1期97-101,共5页
Lubrication Engineering
基  金:国家973项目(2015CB057500);国家自然科学青年基金项目(51305431).
摘  要:采用冷压-热烧结法制备聚苯酯(POB)改性聚四氟乙烯(PTFE)复合材料,考察聚苯酯含量以及在110℃的航空液压油中浸泡后对改性PTFE材料机械性能和摩擦磨损性能的影响。试验结果显示:改性PTFE材料的硬度与聚苯酯含量成正比,而拉伸强度和拉断裂伸长率与聚苯酯含量成反比;改性PTFE材料的摩擦因数随聚苯酯含量增加先增大后减小,体积磨损率则呈减小趋势;改性PTFE材料的摩擦因数随着载荷增大而减小,而磨痕宽度随载荷的增大而增大;质量分数20%聚苯酯改性PTFE的综合性能最优,并且具有很好的稳定性,在航空液压油浸泡后其性能变化不明显。
The PTFE composites reinforced with different content of polybenzoate (POB)filler were prepared by mold- ing-sintering technique.The effects of POB content and 110 ℃ aircraft hydraulic immersion and sliding conditions on the mechanical and tribological behaviors were studied.The results show that with the increasing of the content of POB, the hardness of POB filled PTFE composites is increased, the tensile strength and elongation are decreased,the friction coeffi- cient is first increased and then decreased,the wear rate is decreased.With the increasing in applied load,the friction coef- ficient of POB filled PTFE composites is deceased and the wear rate is increased.20% ( mass fraction) POB filled PTFE composites exhibit excellent comprehensive performance and stability in aircraft hydraulic oil.
关 键 词:聚四氟乙烯 机械性能 摩擦磨损 稳定性
分 类 号:TH117.1[机械工程—机械设计及理论]
聚苯酯填充聚四氟乙烯机械性能和摩擦学性能研究.rar
369.9 KB, 下载次数: 1
售价: 4 氟币  [记录]
GMT+8, 2026-8-6 05:13 , Processed in 0.022766 second(s), 10 queries , Redis On.
