查看: 19021|回复: 1
SAE AMS 2482C-2000(R2006) 铝合金的聚四氟乙烯浸渍共沉积硬镀层
发表于 2010-10-4 06:54:16 |江苏| 显示全部楼层 |阅读模式
SAE AMS 2482C-2000(R2006) 铝合金的聚四氟乙烯浸渍的或共沉积的硬镀层
本压缩包解压密码为:www.myptfe.com
1.1 Form:
This specification establishes the engineering requirements for producing a hard, teflon-impregnated
or codeposited teflon-aluminum oxide coating on aluminum alloys and the properties of such
coating.
1.2 Application:
This process has been used typically to increase, by the formation of a dense, teflon-impregnated
aluminum oxide or codeposited teflon-aluminum oxide layer, surface hardness and resistance to
abrasion and corrosion of aluminum alloy parts containing, in general, less than 5% copper or 8%
silicon or a total of 8% of both. Alloys with higher silicon content alone can be coated satisfactorily
with proper precautions in processing. Careful consideration should be given to the use of this
process on highly-stressed parts because of the resultant marked lowering of fatigue performance,
and on parts with sharp corners and edges where chipping may result.
SAE AMS 2482C-2000(R2006) .rar
32.2 KB, 阅读权限: 10, 下载次数: 4
发表于 2010-10-4 07:57:42 |浙江| 显示全部楼层
好贴好资料就不让他沉下去顶一下。
GMT+8, 2026-10-26 07:27 , Processed in 0.125814 second(s), 8 queries , Redis On.
