查看: 4277|回复: 0
磁性聚四氟乙烯密封材料的制备及性能
发表于 2012-6-12 22:36:30 |江苏| 显示全部楼层 |阅读模式
磁性聚四氟乙烯密封材料的制备及性能
Preparation and performance of magnetic polytetrafluoroethylene sealing material
作  者:何世权[1,2] 饶文武[1] 苏清苗[1]
HE Shi-quan,RAO Wen-wu,SU Qing-miao(1.College of Petrochemical Technology,Lanzhou Univ.of Tech.,Lanzhou 730050,China;2.Wenzhou Research Institute of Pump and Valve Engineering,Lanzhou Univ.of Tech.,Wenzhou 325105,China)
机构地区:[1]兰州理工大学石油化工学院,甘肃兰州730050 [2]兰州理工大学温州泵阀工程研究院,浙江温州325105
出  处:《兰州理工大学学报》 CA 2012年第38卷第1期 20-22页,共3页
Journal of Lanzhou University of Technology
基  金:温州市科技计划项目(H20090039)
摘  要:以纳米Fe3O4为主要增强填料,采用冷压成型和烧结固化工艺制备磁性聚四氟乙烯(PTFE)密封材料.分析不同纳米Fe3O4填充量对材料抗拉强度、断裂伸长率、硬度、线膨胀系数等性能的影响.结果表明:纳米Fe3O4填充量对材料性能具有显著影响,随填充量的增加,硬度增大,抗拉强度先增大后减小,断裂伸长率和线膨胀系数迅速下降.当纳米Fe3O4质量分数为5%时,填料在PTFE基体中分散性较好,硬度和拉伸强度均有所提高,断裂伸长率下降38%,线膨胀系数下降18%,PTFE密封材料性能得到提高.
Taking nano-Fe3O4 as main reinforcing filler,a magnetic polytetrafluoroethylene(PTFE) sealing material was prepared with cold-pressing and sintering process.The effect of the additive amount of nano-Fe3O4 on the tensile strength,breaking elongation,hardness,and coefficient of linear expansion of the sealing material was analyzed.The result indicated that the amount of nano-Fe3O4 could significantly influence the performance of the sealing material.Along with the increase of nano-Fe3O4,the hardness was increased,the tensile strength increased first and then decreased,and the breaking elongation and linear expansion coefficient decreased rapidly.When the mass fraction of nano-Fe3O4 was 5%,the dispersion of nano-Fe3O4 in PTFE matrix was so homogeneous,that the tensile strength and hardness could be increased,the breaking elongation decreased by 38%,and the coefficient of linear expansion decreased by 18%.Therefore,the sealing performance improved.
关键词:纳米四氧化三铁 磁性聚四氟乙烯 密封材料 制备 性能
nano-Fe3O4 ; magnetic polytetrafluoroethylene ; sealing materials ; preparation ; performance ;
分类号:TB332 [工业技术 > 一般工业技术 > 工程材料学 > 复合材料]
全文快照:饶文武,苏清苗(1.兰州理工大学石油化工学院,甘肃兰州730050;2.兰州理工大学温州泵阀工程研究院,浙江温州325105) 摘要:以纳米Fes0 为主要增强填料,采用冷压成型和烧结固化工艺制备磁性聚四氟乙烯(PTFE)密封材料.分析不同纳米Fes0 填充量对材料抗拉强度、断裂伸长率、硬度、线膨胀系数等性能的影响.结果表明:纳米Fe。O 填充量对材料性能具有显著影响,随填充量的增加,硬度增大,抗拉强度先增大后减小,断裂伸长率和线膨胀系数迅速下降.当纳米Fe。O 质量分数为5 时,填料在PTFE基体中分散性较好,硬度和拉伸强度均有所提高,断裂伸长率下降38 ,线膨胀系数下降18 ,PTFE密封材料性能得到提高.关键词:纳米四氧化三铁;磁性聚四氟乙烯;密封材料;制备;性能中图分类号:TB332 文献标识码:A Preparation and performance of magnetic polytetrafluoroethylene sealing material HE Shi—quan ¨,RAO Wen-wu 。SU Qing—miao (1.College of Petrochemical Technology,l~nzhou Univ.of TecK ,Lanzhou 730050,China;2.
磁性聚四氟乙烯密封材料的制备及性能.pdf
248.47 KB, 下载次数: 0
磁性聚四氟乙烯密封材料的制备及性能
GMT+8, 2026-8-18 16:40 , Processed in 0.027466 second(s), 11 queries , Redis On.
