查看: 2637|回复: 0
常温下聚四氟乙烯的湍流超细粉碎研究
发表于 2012-6-24 06:47:03 |江苏| 显示全部楼层 |阅读模式
常温下聚四氟乙烯的湍流超细粉碎研究
贾如磊[1] 龚俊[2][1]兰州石化职业技术学院机械工程系,甘肃兰州730060 [2]兰州理工大学机电工程学院,甘肃兰州730050
摘 要:为探讨湍流粉碎机对塑料进行超细粉碎的机理,利用湍流粉碎机对聚四氟乙烯进行常温超细粉碎的试验。通过试验,对主要粉碎参数如转速、入料粒度和入料速度对粉碎效果的影响进行分析。结果表明:在适宜的参数条件下.湍流粉碎机对聚四氟乙烯进行常温超细粉碎的粒度可以达到d50〈12μm,同时分析聚四氟乙烯在湍流场中进行超细粉碎的机理。[著者文摘]
关键词:聚四氟乙烯 湍流 超细粉碎
分类号: TQ051.91[著者标引]文献标识码:A文章编号:1008-5548(2010)06-0053-03栏目信息:粉体加工与处理
Ultrafine Comminution of Polytetrafluoroethene with Turbulence Mill Under Normal TemperatureJia Rulei, Gong Jun 1. Department of Mechanical Engineering, Lanzhou Petrochemical College of Vocational Technology, Lanzhou 730060; 2. School of Mcchano-electronic Engineering, Lanzhou University of Technology, Lanzhou 730050, ChinaAbstract:To study the ultrafine comminution of some plastic with turbulence mill, the turbulence mill was used to grind polytetrafluoroethene (PTFE) under normal temperature. The effect of key parameters such as rotary speed, particle size and feed rate on the comminuting efficiency was analyzed by experiments. The results showed that the comminuting efficiency of d50〈12 μm got with the feasible comminution parameters. The reasons of ultrafine comminution of PTFE with turbulence mill under normal temperature were simply investigated.[著者文摘]
Key words:polytetrafluoroethene ; turbulence ; ultrafine comminution
常温下聚四氟乙烯的湍流超细粉碎研究.pdf
250.81 KB, 下载次数: 0
常温下聚四氟乙烯的湍流超细粉碎研究
GMT+8, 2026-8-7 14:38 , Processed in 0.023468 second(s), 9 queries , Redis On.
