查看: 2651|回复: 0
多种径向高压密封材料的性能测试与比较
发表于 2012-6-30 22:50:59 |江苏| 显示全部楼层 |阅读模式
多种径向高压密封材料的性能测试与比较
Markus Henzler Werner Haas 沈洁斯图加特大学机械元件研究所,斯图加特70569
摘 要:采用间隙挤出实验和磨损实验,研究了几种高压转轴密封材料的抗间隙挤出性能和抗磨损性能。结果表明:PTFE复合材料的抗间隙挤出和抗变形性能较差,而聚酮和聚氨酯材料的较好;聚酮、超高分子聚乙烯、PTFE复合材料以及聚氨酯的耐磨性能均较好,但PTFE复合材料(PTFE聚合物复合材料除外),尤其是含青铜的PTFE复合材料,对相对旋转面的损伤严重;比较的几种密封材料中,超高分子聚乙烯具有最低的摩擦因数,但其耐高温能力最弱;聚氨酯的摩擦因数与PTFE复合材料处于同一级别。[著者文摘]
关键词:摩擦 磨损 旋转密封 聚四氟乙烯 聚氨酯 间隙挤出
分类号: TB42[著者标引]文献标识码:A文章编号:0254-0150(2010)1-093-5栏目信息:开发应用
Test and Comparison of a Variety of High-pressure Radial Sealing MaterialsMarkus Henzler Werner Haas Shen Jie Institute of Machine Components, University of Stuttgart, Stuttgart 70569, GermanAbstract:Abstract: Using gap-extrusion experiments and wear experiments, the anti-gap extrusion and antiwear properties of sev- eral high-pressure shaft seal materials were studied. The results show that the PTFE composites have poor resistance to gap extrusion and deformation performances, while poly-ketone and polyurethane materials show better performances; the poly- ketone, ultra-high molecular polyethylene, PTFE composite (PTFE polymer composites excluded), particularly bronze PTFE composites, damage the opposite rotating sur- face badly; for the tested several sealing materials, ultra-high molecular polyethylene has the lowest friction coefficient, but the weakest high-temperature resistance performance ; the friction coefficients of polyurethane and the PTFE composites are at the same level.[著者文摘]
Key words:friction ; wear; rotary seal ; PTFE ; polyurethan ; gap extrusion
多种径向高压密封材料的性能测试与比较.pdf
413.43 KB, 下载次数: 5
售价: 1 氟币  [记录]
多种径向高压密封材料的性能测试与比较
GMT+8, 2026-8-7 14:37 , Processed in 0.020374 second(s), 9 queries , Redis On.
