查看: 2735|回复: 0
聚四氟乙烯膜表面的苯胺聚合沉积亲水改性研究
发表于 2012-6-30 22:54:31 |江苏| 显示全部楼层 |阅读模式
田云霞[1] 徐莹[2] 王新[1][1]青岛科技大学橡塑材料与工程教育部重点实验室,青岛266042 [2]青岛华钟制药有限公司,青岛266100
摘 要:采用苯胺(An)分散聚合原位成膜的方法对等离子体预处理的聚四氟乙烯(PTFE)多孔膜进行亲水化改性,实验通过SEM、接触角测量等表征了PTFE膜的结构和表面亲水性质.试验结果表明,PTFE膜表面是内部留有孔道的纤维交织结构,有较强的疏水性;等离子体处理使聚合峰值提前,后期聚合速率增大,有利于An在PTFE膜的表面聚合沉积.接触角测试表明PANI/PTFE复合膜比原始膜的亲水性有了较好的改观.[著者文摘]
关键词:聚四氟乙烯 聚苯胺 等离子体处理 亲水性
分类号: TQ325.4[著者标引]文献标识码:A文章编号:1007-8924(2009)06-0040-05栏目信息:研究报告
Hydrophilic modification of PTFE membrane by in - situ polymerization - deposited polyanilineTIAN Yunxia , XU Ying, WANG Xin1. Key Lab of Rubber- plastics, Ministry of Education, Qingdao University of Science and Technology, Qingdao 266042, China; 2. Qingdao Huazhong Pharmaceuticals Co. , Ltd. , Qingdao 266100, ChinaAbstract:The hydrophilic modification of PTFE porous membrane by plasma was investigated in this paper. Polyaniline was in - situ deposited onto the surface of PTFE during dispersion polymerization of aniline with PTFE membrane dipped in. Plasma treatment conditions mainly influenced the range of induction period and the time corresponding to temperature peak. SEM observation showed the surface of pristine PTFE membrane was composed of polymeric fibers with pores and channels inside. Plasma treatment could be beneficial to the polymerization of aniline. Contact angle test showed that there is a good change on hydrophilic modification of PTFE membrane by insitu deposited polyaniline.[著者文摘]
Key words:polytetrafluoroethylene; polyaniline; plasma processing; hydrophilic
聚四氟乙烯膜表面的苯胺聚合沉积亲水改性研究.pdf
382.06 KB, 下载次数: 0
GMT+8, 2026-8-7 14:37 , Processed in 0.023262 second(s), 8 queries , Redis On.
