查看: 2268|回复: 0
石墨对聚四氟乙烯(PTFE)抗静电性能的影响
发表于 2012-7-4 21:01:54 |江苏| 显示全部楼层 |阅读模式
张永强[1] 任新鑫[1] 浦玉萍[1] 肖汉成[1] 吕广庶[2][1]钢铁研究总院粉末冶金研究室,北京100081 [2]北京理工大学材料学院,北京100081
摘 要:采用冷压成型、热压烧结工艺制备石墨改性聚四氟乙烯(PTFE)复合材料,利用MS—T3000摩擦磨损试验仪和EST102A振动电容式静电计检测摩擦过程中产生的静电电压,并研究了石墨粒径、添加量对PTFE复合材料抗静电性能的影响。试验结果表明,添加石墨可以改善PTFE复合材料的抗静电性能,且添加小粒径石墨(4μm)的效果要明显优于添加大粒径石墨(30μm)的效果,当石墨含量(4μm)为5%时,抗静电性能最优,摩擦过程的静电电压接近于0V。[著者文摘]
关键词:聚四氟乙烯 抗静电 石墨
分类号: TB332[著者标引]文献标识码:A文章编号:栏目信息:热加工工艺技术与材料研究
The Influence of Graphite on the Antistatic Property of PTFEZHANG Yongqiang , REN Xinxin , PU Yuping , XIAO Hancheng , LV Guangshu 1. Powder Metallurgy Laboratory, China Iron & Steel Research Institute Group, Beijing 100081, China; 2. College of Material Engineering, Beijing University of Technology, Beijing 100081,ChinaAbstract:In this paper, the graphite modified PTFE was prepared by cold press molding and hot press sintering. The electro- static voltage generated during the friction process was tested using MS-T3000 friction and wear tester and EST102A vibrating capacitance electrometer. And then the effect of different size and dosage of graphite on the antistatic property of the PTFE was discussed. The results show that the antistatic property of the PTFE could be improved by adding graphite.And the PTFE composite material which add the small particle size of the graphite (4μm) has better antistatic property than the material which add large particle size of graphite(30μm). In conclusion, when the content of graphite (4μm) is 5 %, the PTFE composite material has the best antistatic property, and the electrostatic voltage generated during the friction process is close to 0V.[著者文摘]
Key words: PTFE, Antistatic, Graphite
石墨对聚四氟乙烯(PTFE)抗静电性能的影响.pdf
223.46 KB, 下载次数: 2
售价: 1 氟币  [记录]
GMT+8, 2026-8-7 14:38 , Processed in 0.026071 second(s), 10 queries , Redis On.
