查看: 4825|回复: 0
活性材料PTFE/Al动态压缩性能
发表于 2012-7-7 07:48:43 | 显示全部楼层 |阅读模式
活性材料PTFE/Al动态压缩性能
赵鹏铎[1] 卢芳云[1] 李俊玲[1] 陈荣[1] 徐松林[2] 阳世清[2][1]国防科技大学理学院,湖南长沙410073 [2]国防科技大学航天材料与工程学院,湖南长沙410073
摘 要:采用分离式霍普金森压杆(SHPB)实验技术,研究两种不同配比的聚四氟乙烯/铝(PTFE/Al)活性材料(PA265和PA35)在高应变率下的力学压缩性能与加载反应性能,对比分析了铝含量不同对PTFE/Al活性材料的屈服强度,破坏性能,反应性能的影响。研究结果表明:两种PTFE/Al活性材料存在应变率效应,在应变率1000~8000s^-1范围,PA265的屈服应力为32~44MPa,PA35的屈服应力为40~55MPa。铝含量越高,PTFE/Al的屈服强度越高;在应变率3100~5800s^-1范围内,两种材料的破坏应力基本相同,约为143~153MPa;PA265和PA35的临界反应应力分别为157,163MPa;铝粉含量不能高于35%,否则由于缺少足够的氧化剂(PTFE)而普遍出现不完全燃烧反应的现象。[著者文摘]
关键词:爆炸力学 分离式霍普金森压杆(SHPB) 高应变率 活性材料 聚四氟乙烯(PTFE)
分类号: TQ325.4 TB333[机标]文献标识码:A文章编号:1006-9941(2009)04-0459-04栏目信息:研究论文
The Dynamic Compressive Properties of PTFE/AI Reactive MaterialsZHAO Peng-duo , LU Fang-yun , LI Jun-ling , CHEN Rong , XU Song-lin , YANG Shi-qing 1. College of Science, National University of Defense Technology, Changsha 410073, China ; College of Aerospace and Materials Engineering, National University of Dcfense Technology, Changsha 410073, ChinaAbstract:The dynamic compressive and reactive properties of two kinds of PTFE/Al reactive materials were studied by the split Hopkinson pressure bars(SHPB). The effects of Al content on yield stress, fragmented and reaetive properties of PTFE/Al reactive materials were analyzed. Results show that PTFE/Al is sensitive to the strain rate. In the strain rate range of 1000 - 8000 s ^-1 , the yield stress of PA265 is 32 -44 MPa and the yield stress of PA35 is 40 -55 MPa; the yield stress increases with Al content; the fragmented stress is 143 -153 MPa in the strain rate range of 3100- 5800 s^-1f or the PTFE/Al reactive materials; the critical reactive stresses of PA265 and PA35 are 157 MPa and 163 MPa; partial reaction phenomena appear frequently due to lacking of enough oxidant polytetrafluorethylene (PTFE) , if Al content is higher than 35%.[著者文摘]
Key words:explosion mechanics ; split Hopkinson pressure bar (SHPB) ; high strain rate ; reactive materials ; polytetrafluorethylene (PTFE )
活性材料PTFE/Al动态压缩性能.pdf
343.44 KB, 下载次数: 0
活性材料PTFE/Al动态压缩性能
GMT+8, 2026-3-18 15:27 , Processed in 0.083720 second(s), 25 queries .
