查看: 4025|回复: 0
电力杆塔疏水涂料性能研究
发表于 2012-10-11 19:28:37 |江苏| 显示全部楼层 |阅读模式
电力杆塔疏水涂料性能研究
梁永纯[1] 赵书彦[2] 钟万里[1] 刘福春[2] 林介东[1] 史洪微‘[2] 韩恩厚[2][1]广东电网公司电力科学研究院,广东广州510080 [2]中国科学院金属研究所金属腐蚀与防护国家重点试验室,辽宁沈阳110016
摘 要:以聚氨酯为成膜物质,将聚四氟乙烯(polytetrafluoroethene,PTFE)和聚醚醚酮(polyetheretherketone,PEEK)分别加入涂料中制得具有疏水功能的复合涂料,分别研究不同质量分数的PTFE和PEEK对涂层疏水性能的影响;结果表明当2种物质的质量分数越高,水接触角越大,疏水性能越好;而相同条件下,PEEK涂层的疏水性能比PTFE涂层好。同时,研究紫外老化试验对PEEK涂层性能的影响,结果表明经700h老化试验后涂层的疏水性能变化不明显,光泽保持率在94%以上。实践证明该涂层具有良好的疏水功能及长效性。[著者文摘]
关键词:聚四氟乙烯 聚醚醚酮 疏水功能 水接触角
Study on Performance of Hydraulic Paint for Electric Power Poles and TowersLIANG Yongchun , ZHAO Shuyan , ZHONG Wanli , LIU Fuchun , LIN Jiedong , SHI Hongwei, HAN Enhou 1. Electric Power Research Institute of Guangdong Power Grid Corp., Guangzhou, Guangdong 510080, China; 2. State Key Laboratory of Corrosion Protection of Institute of Metal Research, Chinese Academy of Science, Shenyang, Liaoning 110016, ChinaAbstractolyurethane is taken as film forming matter, and tetrafluoroethlene (PTFE) and polyether ether ketone (PEEK) are respectively added into paint to produce composite materials that are able to discharge. Impacts of PTFE and PEEK with different mass fractions on drainage performance of the coat are studied. The result indicates that when the mass fraction of the two substances is large, water contact angle is proportional to the hydrophobicity. However, under the same circum- stance, PEEK coat is superior to PTFE coat in hydrophobicity. In the mean time, impact of UV aging test on performance of PEEK coat is studied. The result shows that hydrophobicity of the coat changes indistinctively after 700 hours of aging test, gloss retention rate remains above 94%. It is practically proved that the coat is superior in hydrophobicity and durability.[著者文摘]
Key wordsTFE; PEEK; drainage; water contact angle
电力杆塔疏水涂料性能研究.pdf
209 KB, 下载次数: 0
电力杆塔疏水涂料性能研究
GMT+8, 2026-7-15 04:04 , Processed in 0.018089 second(s), 8 queries , Redis On.
