查看: 2892|回复: 0
PVDF传感器在爆炸近区超压测量中的应用研究
发表于 2012-10-13 14:47:48 |江苏| 显示全部楼层 |阅读模式
Application of PVDF sensors in shock wave measurement of near zone of explosion
作  者:任新见[1,2] 陈虎林[3]
REN Xin-jian1,2,CHEN Hu-lin3(1.State Key Laboratory of Explosion Science and Technology,Beijing Institute of Technology,Beijing 100081,China; 2.The Third Engineer Scientific Research Institute,the Headquarter of the General Staff PLA,Luoyang,471023,China; 3.China Airborne Missle Academy,Luoyang 471009,China)
机构地区:[1]北京理工大学爆炸科学与技术国家重点试验室,北京100081 [2]总参工程兵科研三所,河南洛阳471023 [3]中国空空导弹研究院,河南洛阳471009
出  处:《振动与冲击》 EI CSCD 2012年第31卷第12期 146-149页,共4页
Journal of Vibration and Shock
基  金:国家973计划项目(2006CB61200)
摘  要:凝聚相炸药爆炸产生强冲击波、电磁脉冲和光热效应,爆炸近区测试环境非常复杂,常规压阻式硅压力传感器难于满足测试要求。为准确测量装药近区爆炸参数给工程防护结构的爆炸毁伤评估提供参考依据,基于PVDF压电薄膜制作压力传感器,采用分离式霍普金森压杆(SHPB)对自制传感器进行标定;进行TNT化爆试验对自制PVDF传感器测试效果进行考核,并提取试验结果与AutoDyn软件计算结果进行比较。对比表明:测量值与计算值偏差小于10%,爆炸近区超压的试验测量可采用防干扰处理后的PVDF压电传感器解决。
Strong shock wave,electro-magnetic pulse and light-heat effect occur when condensational explosive explodes.Measurement circumstance is formidable in near zone of explosion.Conventional piezo-resistance silicon sensors can’t meet the measurement demand.In order to get the detonation parameters of the near zone of explosion and provide reference values for explosion damage assessment on protective structures,PVDF piezo-electric sensors were made and calibrated with a SHPB.The test of TNT explosion was conducted to examine the validity of the sensors.The difference between test data and calculations with AutoDyn was less than 10%.It was shown that a self-made PVDF piezo-electric sensor after anti-interference treatment is suitable for measurement of shock wave in near zone of explosion.
关 键 词:PVDF SHPB 爆炸近区 冲击波 压电常数
PVDF SHPB near zone of explosion shock wave piezo-electric constant
分 类 号:O383 [数理科学和化学 > 力学 > 爆炸力学]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (12篇)[1]Deshpande V S, Fleck N A. Isotropic constitutive models for metallic foams [ J ]. Journal of the Mechanics and Physics of Solids ,2000(48 ) : 1253 - 1283.
[2]Hanssena A G, Enstoekb L, Langsetha M. Close-range blast loading of aluminium foam panels [ J ]. International Journal of Impact Engineering, 2002 ( 27 ) : 593 - 618.
[3]Raclford D D, MeShane G J, Deshpande V S, et al. The response of clamped sandwich plates with metallicfoam cores to simulated blast loading[ J]. International Journal of Solids and Struetures, 2006 ( 43 ) :2243 - 2259.
[4]卢天健 何德坪 陈常青 等.超轻多孔金属材料的多功能特性及应用[J].力学进展,2006,36(4):517-535.
[5]何德坪 何思渊 尚金堂.超轻多孔金属的进展与物理学[J].物理学进展,2006,26(3/4):346-350.
[6]黄西成 陈裕泽 蒋家桥等.撞击作用下泡沫铝填充结构吸能特征[J].解放军理工大学学报(自然科学版),2007,8(5):470-473.
[7]席道瑛 郑永来.PVDF压电计在动态应力测量中的应用[J].爆炸与冲击,:.
[8]朱文辉 李志勇 周光泉.用PVDF实时测量测量激光诱导的冲击波[J].试验力学,1997,12(2):216-220.
[9]刘剑飞 胡时胜.PVDF压电计在低阻抗介质动态力学性能测试中的应用[J].爆炸与冲击,:.
[10]李焰.[D].长沙:国防科学技术大学,2004.
[11]李焰 张向荣 谭红梅 等.国产PVDF压电薄膜的冲击加载与卸载响应研究[J].高压物理学报,2004,18(3):261-266.
[12]赵红平 叶琳 陆中琪.PVDF压电薄膜在应力波测量中的应用[J].力学与实践,2004,(1):37-41.
PVDF传感器在爆炸近区超压测量中的应用研究.pdf
298.86 KB, 下载次数: 0
GMT+8, 2026-10-21 13:35 , Processed in 0.911620 second(s), 8 queries , Redis On.
