查看: 3626|回复: 0
远程氩等离子体对医用聚四氟乙烯表面灭菌与改性的研究
发表于 2008-12-7 14:33:44 |江苏| 显示全部楼层 |阅读模式
Study on the surface sterilization and modification of medical poly (tetrafluoroethylene) by remote argon plasma
作  者:刘红霞[1,2] 陈杰塔[2]
Liu Hongxia , Chen Jierong (1. School of Life Science and Technology; 2. Department  and Engineering, Xi'an Jiaotong University, Xi'an of Environmental Science 710049, China)
机构地区:[1]西安交通大学生命科学与技术学院,陕西西安710049 [2]西安交通大学环境科学与工程系,陕西西安710049
出  处:《西安交通大学学报:医学版》 CAS CSCD 2008年第29卷第1期 33-37页,共5页
Journal of Xi‘an Jiaotong University:Medical Sciences
基  金:国家自然科学基金资助项目(No.30571636);高等学校博士学科点专项科研基金资助项目(No.20060698002);陕西省科技攻关重点资助项目(No.2003K10-G61);西安市科技攻关资助项目(No.GG06049)
摘  要:目的研究远程氩等离子体对医用聚四氟乙烯(PTFE)表面的灭菌及改性。方法通过载体定量灭菌实验测定远程氩等离子体对PTFE表面大肠杆菌的杀灭效果,并利用接触角测量、质量损失率计算和X射线光电子能谱分析(XPS)研究灭菌前后PTFE表面结构、性能的变化。结果在放电功率100 W,放电时间120 s,氩气流量20 cm3/min的条件下,远程及常规氩等离子体均可有效灭活大肠杆菌(GE≥3.769);但经远程氩等离子体灭菌后,PTFE表面的亲水性(水接触角为58.5°)明显优于常规氩等离子体灭菌后的PTFE表面(水接触角为70.5°),同时受损及降解程度低(表面质量损失率仅为11.8%)。远程氩等离子体可以在一定程度上抑制电子、离子的刻蚀作用,强化自由基反应,对PTFE表面的脱氟作用更强,从而引入更多的含氧基团。结论远程氩等离子体在有效杀灭大肠杆菌的同时,可使PTFE表面获得更好的改性效果。
Objective To investigate the surface sterilization and modification of medical poly (tetrafluoroethylene) (PTFE) by remote argon plasma. Methods Carrier quantitative bactericidal test was used to examine the germicidal effect (GE) of the E. coil on the surface of medical PTFE film and surface structure, performances of sterilized PTFE were characterized by the water contact angle, mass loss and X-ray photoelectron spectroscopy (XPS). Results Both remote and conventional argon plasmas could sterilize effectively(GE≥3. 769) in the conditions of plasma RF power 100 W, exposure time 120 s and argon flux 20 cm^3/min. Remote argon plasma sterilization made the PTFE surface have higher hydrophilicity ( θ = 58.5°) than the conventional argon plasma sterilization ( θ = 70.5°) and did not cause remarkable degradation and damages in terms of the mass loss (mass loss was 11.8%). Remote argon plasma sterilization could enhance interaction reactions with argon radicals relative to those with electron and argon ions, thereby contributing more effectively to defluorination (F/C= 2.24) from the PTFE than the conventional argon plasma sterilization (F/C = 2. 49) and more effectively to the formation of oxygen functionalities on the PTFE surface. Conclusion Remote argon plasma can inactivate E. coli effectively and at the same time bring better surface modification of PTFE.
关 键 词:远程氩等离子体 大肠杆菌 灭菌 PTFE 表面改性
remote argon plasma Escherichia coil sterilization poly (tetrafluoroethylene) (PTFE) surface modification
分 类 号: R187 [医药、卫生 > 预防医学、卫生学 > 流行病学与防疫]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (11篇)[1]Moisan M, Barbcau J, Morcau S, et al, Low-temperature sterilization using gas plasmas: a review of the experiments and an analysis of the inactivation mechanisms[J]. Int J Pharm, 2001, 226 (1/2) : 1-21.
[2]Laroussi M, Leipold F. Evaluation of the roles of reactive species, heat, and UV radiation in the inactivation of bacterial cells by air plasmas at atmospheric pressure [J]. Int J Mass Spectrom, 2004, 233(1-3):81-86.
[3]Kaczmarek H, Kowalonek J, Szalla A, et al, Surface modification of thin polymeric films by air-plasma or UV-irradiation [J]. Surf Sci, 2002, 507-510:883-888.
[4]Choi JH, Han I, Balk HK, et al. Analysis of sterilization effect by pulsed dielectric barrier discharge [J]. J Electrostatic, 2006, 64(1) :17-22.
[5]Lee KY, Park BJ, Lee DH, et al. Sterilization of Escherichia coli and MRSA using microwave-induced argon plasma at atmospheric pressure [J]. Surf Coat Technol, 2005, 193(1-3):35-38.
[6]Chen JR, Yan JL, Zhang YZ, Surface modification of medical PVC by remote oxygen plasma [J]. Compos Interface, 2004, 11(2) : 123-130.
[7]张文福.医学消毒学[M].北京:军事医学科学出版社,2002.108-111.
[8]Chantal EH, Chantclle C, John ED, et al. Optimizing the sterilization of PLGA scaffolds for use in tissue engineering[J]. Biomaterials, 2001, 22(1):25-31.
[9]Annemie B, Renaat G, Wim G. Comparison between a radiofrequency and direct current glow discharge in argon by a hybrid Monte Carlo-fluid model for electrons, argon ions and fast argon atoms [J]. Spectrochim Acta Part B, 1999, 54(9):1335- 1350.
[10]Dhayal M, Forder D, Parry KL, et al. Using an afterglow plasma to modify polystyrene surfaces in pulsed radio frequency (RF) argon discharges [J]. Surf Coat Technol, 2003, 173-174: 872-876.
[11]Goldman A, Amouroux J. Plasma chemistry [M] // Kunhardt EE, Lusscn LH, Electrical breakdown and discharge, s in gases, macroscopic processes and discharges, New York: Plenum, 1983: 293-346.
远程氩等离子体对医用聚四氟乙烯表面灭菌与改性的研究.pdf
221.95 KB, 下载次数: 37
GMT+8, 2026-7-14 23:13 , Processed in 0.037902 second(s), 10 queries , Redis On.
