查看: 2964|回复: 0
燃料电池催化层的结构增强与物理耐久性
发表于 2012-10-15 18:23:54 |江苏| 显示全部楼层 |阅读模式
燃料电池催化层的结构增强与物理耐久性
Structure enhancement and physical durability of hydrophilic catalyst layer for PEM fuel cell
作  者:唐建均 潘牧 唐浩林
TANG Jian-jun,PAN Mu,TANG Hao-lin(State Key Laboratory of Advanced Technology for Materials Synthesis and Processing, Wuhan University of Technology,Wuhan,Hubei 430070,China)
机构地区:武汉理工大学材料复合新技术国家重点实验室,湖北武汉430070
出  处:《电池工业》 CAS 2011年第16卷第4期 235-238页,共4页
Chinese Battery Industry
基  金:国家高技术研究发展计划重大项目(2008AA11A106)
摘  要:亲水催化层在湿度循环条件下产生的结构破坏,是目前CCM(Catalyst Coated Membrane)膜电极退化的重要原因。本研究采用复合胶体技术,在亲水催化层中添加聚四氟乙烯(PTFE)结构增强相制备了PTFE/Nafion亲疏水催化层及其CCM膜电极。干湿循环耐久性测试结果表明,PTFE结构增强可以显著提高催化层的抗溶胀应力能力,从而提高CCM膜电极的物理稳定性。
Microstructure decay of the hydrophilic catalyst layer under long-term humidity cycles is one of the most important issues for CCM(catalyst coated membrane) degradation.Approach in the current research was adding hydrophobic PTFE(polytetrafluoroethylene) into the catalyst layer to form a hydrophilic/hydrophobic PTFE/Nafion catalyst layer by a composite colloid methodology.The results demonstrated that the hydrophilic/hydrophobic phase could obviously reduce the humidity-induced stress and improve the physical stability of the catalyst layer and the CCM under humidity cycle conditions.
关 键 词:质子交换膜燃料电池 亲水催化层 聚四氟乙烯 物理耐久性
proton exchange membrane fuel cell(PEMFC) hydrophilic catalyst layer polytetrafluoroethylene physical durability
分 类 号:TM911.4 [工业技术 > 电工技术 > 独立电源技术(直接发电) > 化学电源、电池、燃料电池]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (8篇)[1]Koeha S S. Principles of MEA preparation [C]//Handbook of fuel cells-fundamentals, technology and applications. Wiely, Volume 4, 2003: 538.
[2]Akita T, Taniguchi A, Maekawa J, et al. Analytical TEM study of Pt particle deposition in the proton-exchange membrane of a membrane-electrode-assembly [J]. Journal of Power Sources 2006,159(1):461-467.
[3]Leimin X, Shijun L, Lijun Y, et al Investigation of a novel catalyst coated membrane method to prepare low-platinum- loading membrane electrode assemblies for PEMFCs [J]. Fuel CeUs,2009,9(2): 101-105.
[4]Sun L L, Ran R, Shao Z P. Fabrication and evolution of catalyst-coated membranes by direct spray deposition of catalyst ink onto Nation membrane at high temperature [J]. International Journal of Hydrogen Energy, 2010,35 (7):2921- 2925.
[5]Kang J, Kim J. Membrane electrode assembly degradation by dly/wet gas on a PEM fuel cell [J]. International Journal of Hydrogen Energy ,2010,35(23):13125-13130,.
[6]Tang HL, Wang F, Pan M. A degradation study of Nation proton exchange membrane of PEM fuel cells [J]. Journal of Power Sources 2007,170(1):85-92.
[7]rang H L, Pan M, Wang F. Highly durable proton exchange membranes for low temperature fuel cells [J]. Journal of Physical Chemistry B 2007,111(30):8684-8690.
[8]唐浩林 潘牧 王洪红.一种亲疏水性可调的质子交换膜燃料电池用核心组件的制备方法[P].中国发明专利 CN1862855.2006.
燃料电池催化层的结构增强与物理耐久性.pdf
391.8 KB, 下载次数: 0
燃料电池催化层的结构增强与物理耐久性
GMT+8, 2026-7-15 02:14 , Processed in 0.019476 second(s), 8 queries , Redis On.
