查看: 3940|回复: 0
磁控溅射法在涤纶织物上制备氟碳薄膜
发表于 2012-10-15 18:41:27 |江苏| 显示全部楼层 |阅读模式
磁控溅射法在涤纶织物上制备氟碳薄膜
Magnetron Sputtering Used to Prepare Fluorocarbon  Coatings Deposited on PET Fabrics
作  者:黄美林 狄剑锋 齐宏进
HUANG Mei-lin, DI Jian-feng, QI Hong-jin ( Wuyi University, Jiangmen 529020, China )
机构地区:五邑大学,广东江门529020
出  处:《高分子材料科学与工程》 EI CAS CSCD 2008年第24卷第2期 148-151页,共4页
Polymer Materials Science & Engineering
摘  要:用磁控溅射法在涤纶(PET)织物上制备纳米氟碳薄膜,研究了磁控溅射过程中不同PET织物布样、溅射功率、工作气压和基底温度对薄膜性能的影响。对氟碳膜的成膜组分进行了研究,并对溅射后的织物进行了拒水性能和抗紫外性能的测试和分析。
Fluorocarbon coatings deposited on PET fabrics were prepared by means of magnetron sputtering, and effects of parameters (type of fabric, power, pressure, temperature) on the applied properties of those fluorocarbon coatings were studied. The waterproof capability and ultraviolet resistance of the PET fabrics after sputtering were tested and analyzed. Results indicate that the film thickness increases when sputtering time increases and hence the waterproof and ultraviolet-resistance of the sample increases. During a given sputtering time, the increase in power can lead to increase in waterproof and ultraviolet-resistance of the sample, but the effect of power is no longer obvious as the thickness reaches to a certain value.
关 键 词:磁控溅射 涤纶 聚四氟乙烯 氟碳薄膜
magnetron sputtering PET PTFE ftuorocarbon coating
分 类 号:TB383 [工业技术 > 一般工业技术 > 工程材料学]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (10篇)[1]Biederman H.Vacuum,1981,7(31):285-289.
[2]Matinu L, Biederman H. Vacuum, 1986, 7-9(36) : 477 - 478.
[3]Shishoo R, Journal of Coated Fabrics, 1996, 26: 27-35.
[4]王东 齐宏进.磁控溅射法制备防水透湿织物的性能研究[J].棉纺织技术,:.
[5]孙银洁 马林 齐宏进.磁控溅射法制备防水透湿织物[J].高分子材料科学与工程,2003,19(4):188-191.
[6]中国科学院数学研究所统计组(StatisticsGroupofCASMathGraduateSchool)编.常用数理统计方法(Gommon Mathematical Statistics)[M].科学出版社(Science Press),1979..
[7]Cassie A, Baxter S. Trans. Faraday Soc. 1944, 40:546 -551.
[8]Mathias E, Miller G H. The Joural of Physical Chamistry, 1967, 8: 2671-2675.
[9]Giegengack H, Hinze D. Phys. Stat. Sol. A, 1971, 8 (2): 513-520.
[10]Pratt I H, Lausman T C. Thin Solid Films, 1972, 10: 151-154.
磁控溅射法在涤纶织物上制备氟碳薄膜.pdf
196.64 KB, 下载次数: 0
磁控溅射法在涤纶织物上制备氟碳薄膜
GMT+8, 2026-9-27 05:17 , Processed in 0.032526 second(s), 9 queries , Redis On.
