查看: 2740|回复: 0
聚四氟乙烯微孔膜亲水性与抗污性的关系研究
发表于 2012-12-11 20:57:49 |江苏| 显示全部楼层 |阅读模式
Relationship between the Hydrophilicity and Antifouling Performance  of Polytetrafluoroethylene (PTFE) Microporous Membrane
作  者:王峰 朱海霖 郭玉海
WANG Feng, ZHU Hai-lin, GUO Yu-hai (The Key Laboratory of Advanced Textile Materials and Manufacturing Technology (Zhejiang Sic-Tech University), Ministry of Education, Hangzhou 310018, China)
机构地区:浙江理工大学先进纺织材料与制备技术教育部重点实验室,杭州310018
出  处:《浙江理工大学学报》 2012年第29卷第5期 641-645页,共5页
Journal of Zhejiang Sci-tech University
基  金:教育部新世纪优秀人才支持计划(NCET-10-0980)
摘  要:探讨错流过滤中聚四氟乙烯微孔膜亲水性与抗污性的关系。在聚四氟乙烯(PTFE)膜表面引入磺酸基(-SO3H),通过扫描电镜(SEM)、傅里叶红外光谱(FTIR)、固体表面电位分析仪(SurPASS)等研究-SO3H含量对膜亲水性、Zeta电位、牛血清蛋白(BSA)静态吸附量及水通量的影响。结果表明:疏水的PTFE膜易吸附负离子,Zeta电位〈0,BSA吸附量高,水通量降幅大,抗污性差;经过亲水改性后,由于-SO3H的引入,膜表面不易吸附负离子,Zeta电位升高,BSA吸附量降低,水通量降幅小;随-SO3H含量增加,膜Zeta电位因-SO3H电离而降低,与负电性BSA之间的静电斥力增强,抗污性进一步提高。
The relationship between the hydrohilicity and antifouling performance of polytetrafluoroethylene (PTFE) microporous membrane in cross-flow filtration is determined. The effects of the sulfonic group (-SO3H) on the water contact angle, Zeta potential, static absorption of bovine serum albumin (BSA), and water flux were studied by scanning electron microscopy, Fourier-transform infrared spectros-copy, and surface potential analysis of solid surface after introducing -SO3 H onto the surface of a PTFE membrane. The Zeta potential is negative, owing to the absorption of electronegative ion onto the hydro-phobic PTFE membrane. The PTFE membrane shows abundant static absorption of BSA and obviously decreased water flux, which demonstrates a weak antifouling property. However, the PTFE/P(AA-co-NaSS) composite membrane shows excellent antifouling performance because the introduction of -SO3 H makes the absorption of electronegative ions and BSA difficult. The electrostatic repulsion between the membrane and BSA is enhanced because the Zeta potential becomes more negative with increased -SO3 from the ionization of -SO3 H, which improves the antifouling performance.
关 键 词:聚四氟乙烯 薄膜 抗污性 Zeta电位 静电斥力
polytetrafluoroethylene membrane membrane fouling Zeta potential electrostatic repulsion
分 类 号: TQ028.8 [工业技术 > 化学工业 > 一般性问题 > 化工过程(物理过程及物理化学过程) > 分离过程]
相似文献与本文研究主题相似的文献,反映同类研究现状。 (10篇)[1]五粮液普什醋酸纤维素二期工程开工
[2]欧洲薄膜再生项目为农业领域带来新突破
[3]聚乙二醇超滤过程的考察及模型化分析
[4]芳香族化合物的快速生物降解性QSBR研究
[5]双极膜电渗析提取乳酸的影响因素
[6]MAPTES-Fe_3O_4的制备及作为可回收驱动液的研究
[7]稀HCl/硅烷偶联剂处理E-玻璃纤维对BMC的增强
[8]界面膜技术在婴幼儿配方奶粉生产工艺中的应用
[9]离子排斥色谱法分析饮用矿泉水中总碳酸盐
[10]超滤处理糖蜜酒精废液中膜清洗方法的研究
聚四氟乙烯微孔膜亲水性与抗污性的关系研究.pdf
295.51 KB, 下载次数: 0
GMT+8, 2026-7-15 00:54 , Processed in 0.018630 second(s), 11 queries , Redis On.
