查看: 3669|回复: 0
超疏水聚四氟乙烯丝网用于原油脱水的研究
发表于 2012-12-11 21:01:15 |江苏| 显示全部楼层 |阅读模式
超疏水聚四氟乙烯丝网用于原油脱水的研究
The Study of Crude Oil Dehydration Using Super-Hydrophobic PTFE-Coated Wire Mesh
作  者:刘君腾[1] 卿伟华[1] 任钟旗[1] 袁海涛[2] 张卫东[1]
LIU Jun-teng, QING Wei-hua, REN Zhong-qi, YUAN Hai-tao, ZHANG Wei-dong (1. State Key Laboratory of Chemical Resource Engineering, Beij ing University of Chemical Technology,  Beijing 100029, China;  2. Oil/Gas Process BR, Donghao Co., Daqing Oilfield Chemical Co.,Ltd., Daqing 163453, China)
机构地区:[1]北京化工大学化工资源有效利用国家重点实验室,北京100029 [2]大庆油田化工有限公司东昊公司油气处理分公司,黑龙江大庆163453
出  处:《高校化学工程学报》 EI CAS CSCD 2012年第26卷第4期 563-568页,共6页
Journal of Chemical Engineering of Chinese Universities
摘  要:开发节能、高效的原油脱水技术是石油开采、炼制企业面临的难题之一。今采用超疏水性聚四氟乙烯丝网进行原油脱水,首先对丝网的表面形貌结构进行了分析,然后采用错流过滤,考察了过滤压降、初始含水量、过滤级数对脱水效果的影响,并对分离机理进行讨论。实验结果表明:所用聚四氟乙烯丝网具有粗糙的表面结构,其水的静态接触角高达159°;该超疏水丝网能有效脱除原油中的水分,随着操作压降的降低或初始含水量的升高,脱水率会上升,但原油通量会相应下降;经过二级过滤,后侧含水量低于国家标准0.5%(w/w),达到国家原油外输标准(SY 7513-1988)。
To develop a crude oil dehydration technology with energy saving and high efficiency is one of the difficult problems in the petroleum mining and refining industry. In this study, a super-hydrophobic PTFE coated wire mesh was used to separate the water from the crude oil. The surface topography structure of the wire mesh is studied by SEM at first, then using crosstlow filtration, the influences of the filtration pressure, initial water content, and filtration stages on the water removal efficiency were investigated. The filtration mechanism was also discussed. The results show that the surface of PTFE-coated wire mesh is extremely rough, and the static contact angle of water on it reaches as high as 159~; the super-hydrophobie PTFE coated wire mesh can separate the water from the oil efficiently. With decreasing the pressure drop or increasing the initial water content, the dehydration ratio increases whereas the flux of crude oil decreases; and the water content of the crude oil after two-stage filtration is lower than 0.5%(w/w) and conforms to the national standard of SY 7513-1988.
关 键 词:超疏水 聚四氟乙烯丝网 原油脱水 乳化水 破乳
super-hydrophobic PTFE-coated wire mesh crude oil dehydration water-in-oil emulsion demulsification
分 类 号: TQ028.4 [工业技术 > 化学工业 > 一般性问题 > 化工过程(物理过程及物理化学过程) > 分离过程] TE624.1 [工业技术 > 石油、天然气工业 > 石油、天然气加工工业 > 石油炼制 > 炼油工艺过程]
相似文献与本文研究主题相似的文献,反映同类研究现状。 (10篇)[1]乙腈-硫酸铵-水三元体系相平衡的研究
[2]山苍子油减压连续精馏分离提纯柠檬醛的工艺模拟
[3]基于组态和仿真技术的化工实验系统
[4]大孔吸附树脂富集板蓝根中(R,S)-告依春工艺研究
[5]“背包式”反应精馏水解乙酸甲酯的工艺
[6]工业醋酸脱水过程五元体系非均相共沸精馏的流程模拟
[7]液膜分离技术在医药化工中的应用研究
[8]疏水层析技术及应用
[9]超疏水聚四氟乙烯丝网用于原油脱水的研究
[10]艾蒿油乳液稳定性的油相离心系数法表征
超疏水聚四氟乙烯丝网用于原油脱水的研究.pdf
602.01 KB, 下载次数: 0
超疏水聚四氟乙烯丝网用于原油脱水的研究
GMT+8, 2026-7-15 00:52 , Processed in 0.225929 second(s), 10 queries , Redis On.
