查看: 4302|回复: 0
一种多路流体关节机构的研究
发表于 2013-1-1 09:55:39 |江苏| 显示全部楼层 |阅读模式
一种多路流体关节机构的研究
Research on a multiway fluid joint mechanism
作  者:高云国[1] 唐国栋[1,2] 韩光宇[1]
GAO Yun-guo , TANG Guo-dong, HAN Guang-yu  (1. Changchun Institute of Optics ,Fine Mechanics and Physics,  Chinese Academy of Sciences , Changchun 130033,China ;2. Graduate School of the Chinese Academy of Sciences ,Beijing 100039,China)
机构地区:[1]中国科学院长春光学精密机械与物理研究所,吉林长春130033 [2]中国科学院研究生院,北京100039
出  处:《光学精密工程》 EI CAS CSCD 2007年第15卷第10期 1564-1570页,共7页
Optics and Precision Engineering
基  金:中国科学院创新基金资助项目(No.Q05C06Z)
摘  要:根据大型光电经纬仪提出的温度控制要求,研制了多路流体关节机构。介绍了机构研究背景,说明了该机构的组成及工作原理,并通过计算摩擦阻力矩验证了机构的可行性,最后通过实验验证设计的合理性。实验结果表明,当用添加青铜的聚四氟乙烯制作的密封隔环进行密封时,能做到不泄漏,造成的摩擦阻力矩仅为1.666 N.m。该机构工作可靠,实现了流体由静到连续转动的传输,结构紧凑,设计巧妙,完全可以满足大型高精度光电设备的使用要求。
According to the temperature control requirements of a large photoelectric theodolite, a compact multiway fluid joint mechanism with skillful structure is researched and designed. The mechanism research background is introduced and the composition and principle of the mechanism are presented. The feasibility of the structure is verified through calculating the friction resistance torque. Finally, the reasonability of the structural design is verified through the theoretical analysis and experimental results. The experimental results indicate that the mechanism is no leak when the sealing ring made of PTFE combined with the bronze is utilized to seal, and the friction resistance torque is only 1. 666 N · m. The mechanism runs reliably and realizes the fluid transmission from static state to the continuous rotated state, which can meet the performance requirements of large photoelectric instrumentations properly.
关 键 词:光电经纬仪 光电跟踪 温度控制 摩擦阻力矩 聚四氟乙烯
photoelectric theodolite photoelectric tracking temperature control friction resistance torque PTFE
分 类 号: V556.5 [航空、航天 > 地面设备、试验场、发射场、航天基地 > 地面测量控制系统] TP211.3 [工业技术 > 自动化技术、计算机技术 > 自动化技术及设备 > 自动化元件、部件 > 一般自动化元件、部件]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (7篇)[1]崔敦杰.关于红外探测器与红外焦平面阵列探测器性能参数描述方法的商榷[J].光学精密工程,2003,11(3):265-268.
[2]张景旭.大型跟瞄架方位轴系的研制[J].光学精密工程,1996,4(2):73-77.
[3]王金亮 王鹏宇.自补偿型主轴密封在万家寨机组上的应用[J].电力学报,2005,20(2):207-209.
[4]姜继海 胡志栋.静压滑环及其应用研究[J].工程设计学报,:.
[5]钱德森.PTFE密封的发展和现状[J].润滑与密封,1998,26(4):69-70.
[6]王文东 师延龄.聚四氟乙烯复合材料与弹性体组合应用[J].有机氟工业,2005(1):11-14.
[7]成大先.机械设计手册(7版)[M].北京:化学工业出版社,2002..
一种多路流体关节机构的研究.pdf
340.94 KB, 下载次数: 0
一种多路流体关节机构的研究
GMT+8, 2026-7-14 23:12 , Processed in 0.023799 second(s), 11 queries , Redis On.
