查看: 5244|回复: 1
FKM/PTFE/炭黑复合材料的性能研究
发表于 2009-6-25 18:42:35 |江苏| 显示全部楼层 |阅读模式
Properties of FKM/PTFE/carbon black composites
作  者:李恩军 张勇 任文坛 王仕峰
LI En-jun ,ZHANG Yong ,REN Wen-tan ,WANG Shi-feng  (Shanghai Jiaotong University,Shanghai 200240,China)
机构地区:上海交通大学化学化工学院,上海200240
出  处:《橡胶工业》 CAS 2009年第56卷第1期 20-24页,共5页
China Rubber Industry
摘  要:在氟橡胶(FKM)/炭黑共混体系中加入聚四氟乙烯(PTFE)微粉,制备FKM/PTFE/炭黑复合材料,并对其性能进行研究。结果表明,采用PTFE微粉部分替代炭黑,硫化胶的拉伸强度、拉断伸长率及撕裂强度均明显增大,耐磨性能提高,压缩永久变形有所减小,脆性温度大大降低,但低温回弹性变差。FKM/PTFE/炭黑复合材料的热稳定性降低,在452℃出现FKM热质量损失峰后,在551℃又出现了PTFE热质量损失峰。
The FKM/PTFE/carbon black composites were prepared by adding PTFE powder into FKM/carbon black composites, and their properties were investigated. The results showed that, by partly replacing carbon black with PTFE, the tensile strength, elongation at break and tear strength of FKM/PTFE/carbon black composites improved obviously,the abrasion resistance increased, the compression set decreased and the brittle point reduced, but the low temperature resilience became poor. The thermal stability of FKM/PTFE/carbon black composites decreased, the thermal weight loss peak of FKM occured at 452 ℃,and that of PTFE was at 551℃.
关 键 词:氟橡胶 聚四氟乙烯 炭黑 复合材料
FKM PTFE carbon black composites
分 类 号:TQ325.4 [工业技术 > 化学工业 > 合成树脂与塑料工业 > 聚合类树脂及塑料] TB33 [工业技术 > 一般工业技术 > 工程材料学]
参考文献作者在撰写文献时引用的其他文献,反映本文的背景或依据。 (9篇)[1]M Abdul Kader, Min-Young Lyu,Changwoon Nah. A study on melt processing and thermal properties of fluoroelastomer nanocomposites[J]. Composites Science and Technology, 2006,66(10):1 431-1 443.
[2]M Abdul Kader, Changwoon Nah. Influence of clay on the vulcanization kinetics of fluoroelastomer nanocomposites[J]. Polymer,2004,45(7) :2 237-2 247.
[3]Maria Cristina Righetti, Giuseppe Ajroldi, Manuele Vitali, et al. Influence of solvent and filler on some physical properties of a fluoroelastomer[J]. Journal of Applied Polymer Science, 1999,73(3) : 377-384.
[4]平琳 王志成.填充纳米金刚石微粉氟橡胶高温性能研究[J].化工新型材料,2006,34(5):55-56.
[5]徐竹 马俊辉 陈军 等.不同填料对246型氟橡胶性能的影响[J].,2005,26(6):21-23.
[6]雷海军 郑元锁 乐贵强 等.短纤维增强氟橡胶的高温强伸性能研究[J].橡胶工业,2003,50(10):589-591.
[7]陈旭东 刘林 许家瑞 章明秋 龚高平 马青华 董作敬.舰船用高性能密封橡胶研究(Ⅱ)纳米补强填料对氟橡胶硫化胶物理性能的影响[J].弹性体,2004,14(4):.
[8]Gangal S V. Polytetrafluoroethylene, Homopolymers of Tetrafluoroethylene,Encyclopedia of Polymer Science and Engi neering(2nd) [M]. New York:John Wiley & Sons, 1989 : 577-600.
[9]Baker B B, Kasprzak D J. Thermal degradation of commercial fluoropolymer in air[J]. Polymer Degradation and Stability, 1994(2) ,42 : 181-188.
FKM/PTFE/炭黑复合材料的性能研究.pdf
294.03 KB, 下载次数: 93
发表于 2010-1-11 13:47:18 |广东| 显示全部楼层
谢谢你的资料!
GMT+8, 2026-7-15 00:32 , Processed in 0.021893 second(s), 8 queries , Redis On.
