查看: 3493|回复: 0
无油润滑、高压动密封件复合表面处理工艺研究
发表于 2009-8-2 12:49:53 |江苏| 显示全部楼层 |阅读模式
摘 要:4102B型发动机无油润滑动密封件活塞杆,经过复合表面处理,有效的提高了两个对磨密封件的耐磨损性能。本文详细分析了活塞杆磨损失效的原因,着重介绍了活塞杆复合表面处理的工艺过程。关键词:活塞杆 轴密封 聚四氟乙烯 纳米黑金刚膜 舍夫氮化
Compound Surface Processing Craft Research on Lubrication without Oil or High Pressure Moving Seal PartCHEN Wenyun,HOU Huijun 1. China Shipping Ninth Design Academe Engineering Limited Company, Shanghai 200063, China; 2. Research Institute of Materials Surface, Guangzhou Research Institute of Nonferrous Metal, Guangzhou 510650, ChinaAbstract:The 4102B type special kind engine has a piston pole party that has no oil lubricate to seal part in moving shoes, It has been complexed surface processing, it is improved a bear to wear away function of double seal part effective. This paper emphasized introduces craft research of a piston pole complex surface processing.
Key words: Piston pole, Shaft seal, Polyethylene, Nano DLC coating, SHEFU nitride
无油润滑、高压动密封件复合表面处理工艺研究.pdf
291.9 KB, 下载次数: 0
GMT+8, 2026-7-15 00:21 , Processed in 0.054943 second(s), 9 queries , Redis On.
