查看: 4531|回复: 0
国产聚四氟乙烯纤维的特性与应用
发表于 2009-9-6 09:11:10 |江苏| 显示全部楼层 |阅读模式
摘 要:介绍了聚四氟乙烯(PTFE)的化学、物理等特性及其应用。PTFE为大分子线型结构,熔点327℃,分解温度在415℃以上。PTFE纤维具有优良的耐腐蚀性,低摩擦因数,不燃,能耐强酸、强碱、强氧化剂等强腐蚀性试剂或溶剂,耐高、低温性能优良。用PTFE纤维制成的滤材广泛应用于垃圾焚烧、高硫煤除尘等领域。
关键词:聚四氟乙烯 性能 应用 白色
Characteristics and Applications of Local Made Polytetrofluorethylene FiberHE Zheng-xing Changzhou Xingeheng Polymer Material Co.Ltd., Changzhou jiangsu 213013Abstract:The chemical and physical characteristics and applications of polytetrafluoroethylene (PTFE) fiber are introduced, PTFE is a high molecular linear structure, the melting point is 327 ℃ and decomposition temperature is above 415 ℃. PTFE fiber has good corrosion resistance, low friction factor, nonflame, strong acid and strong alkali resistance, high temperature and low temperature resistance. PTFE fibers are widely used in the refuse burning and dust removal of high sulphur coal.
Key words: PTFE, property, application, white
国产聚四氟乙烯纤维的特性与应用.pdf
264.08 KB, 下载次数: 3
售价: 1 氟币  [记录]
GMT+8, 2026-7-14 23:13 , Processed in 0.280740 second(s), 11 queries , Redis On.
