查看: 3451|回复: 0
聚丙烯/聚四氟乙烯纤维复合材料力学性能及发泡行为研究
发表于 2018-9-24 21:29:08 |江苏| 显示全部楼层 |阅读模式
Study on Mechanical Properties and Foaming Behavior of PP/PTFE Fiber Composites
作  者:周海 石阳阳 李荣群 夏洋 李飞
Zhou Hai;Shi Yangyang;Li Rongqun;Xia Yang;Li Fei(Orinko Advanced Plastic Co.Ltd.Hefei 230012,China)
机构地区:合肥会通材料有限公司,安徽合肥230012
出  处:《塑料科技》2018年第2期25-29,共5页
Plastics Science and Technology
摘  要:将聚四氟乙烯纤维和相容剂加入聚丙烯中,在二次开模条件下注塑成型制备出聚丙烯/聚四氟乙烯纤维微发泡复合材料,研究了聚四氟乙烯纤维用量对复合材料力学性能、耐热性及发泡行为的影响。结果表明:当聚四氟乙烯纤维用量为2%时,复合材料的拉伸强度提高了13%,弯曲模量提高了16%;聚丙烯微发泡复合材料具有完美的泡孔结构,其泡孔平均直径为71μm,泡孔密度为1.26×10^6个/cm^3。
The polytetrafluoroethylene(PTFE) fiber and compatilizer was added into polypropylene(PP). The microcellular foamed PP/PTFE fiber composites were prepared by injection method under the condition of twice-open mold. The effects of the amount of PTFE fiber on the mechanical properties, heat resistance and foaming behavior of the composites were studied. The results show that: when the amount of PTFE fiber is 2%, the tensile strength of the composite is increased by 13%, and the flexural modulus is increased by 16%. The PP microfoam composite has a perfect pore structure. The average diameter of the bubble hole is 71 μm, and the density of the bubble hole is 1.26×10~6 cell/cm~3.
关 键 词:聚丙烯 聚四氟乙烯纤维 化学微孔发泡 二次开模
分 类 号:TQ325.14[化学工程—合成树脂塑料工业]
聚丙烯_聚四氟乙烯纤维复合材料力学性能及发泡行为研究.part1.rar
2 MB, 下载次数: 0
售价: 2 氟币  [记录]  [购买]
聚丙烯_聚四氟乙烯纤维复合材料力学性能及发泡行为研究.part2.rar
1.49 MB, 下载次数: 0
GMT+8, 2026-10-5 02:59 , Processed in 0.050374 second(s), 9 queries , Redis On.
