查看: 2458|回复: 0
膨体聚四氟乙烯假体隆鼻整形的效果:随机对照临床试验...
发表于 2018-9-24 21:38:02 |江苏| 显示全部楼层 |阅读模式
膨体聚四氟乙烯假体隆鼻整形的效果:随机对照临床试验方案  被引量:2
Effect of expanded polytetrafluoroethylene prosthesis in rhinoplasty: study protocol for a randomized controlled clinical trial
作  者:李建民
Li Jian-min (Department of Otorhinolaryngology, Qinghai University Affiliated Hospital, Xining 810001, Qinghai Province, China)
机构地区:青海大学附属医院耳鼻喉科,青海省西宁市810001
出  处:《中国组织工程研究》2017年第6期980-984,共5页
Journal of Clinical Rehabilitative Tissue Engineering Research
摘  要:背景:在隆鼻整形术中,当前使用较多的材料有肋软骨、耳软骨、造牙材料、固体硅胶软组织等,但在长期的临床实践中,术后排斥反应、假体下移、鼻梁假体表面皮肤发红等不良反应发生率较高,导致效果不甚满意。目的:探讨聚四氟乙烯假体隆鼻矫正低鼻伴鼻小柱短小的疗效,并进一步验证其生物相容性。方法/设计:研究为前瞻性、单中心、随机对照、开放性临床试验方案,在中国青海省西宁市,青海大学附属医院完成。选取2014年1月至2015年6月入院的在耳鼻喉科进行隆鼻整形术的患者100例,随机分为试验组和对照组,每组50例。试验组采用聚四氟乙烯假体植入,对照组采用固体硅胶软组织植入,术后随访12个月。主要观察指标为两组患者术后12个月满意度;次要观察指标为术后12个月两组鼻部塑型指标变化情况,两组超声检查显示的鼻内部软组织改变情况以及不良反应发生率。试验经中国青海省西宁市青海大学附属医院伦理委员会批准。研究符合世界医学会制定的《赫尔辛基宣言》的要求。参与者对治疗方案和过程均知情同意,并签署知情同意书。讨论:膨体聚四氟乙烯假体与硅胶假体应用于隆鼻术均具有较高的生物安全性。与硅胶假体比较,膨体聚四氟乙烯假体隆鼻术能有效矫正低鼻伴鼻小柱短小,手术创伤小,术后鼻部外观好,患者满意高,可作为软组织填充材料广泛应用于鼻整形外科。
BACKGROUND: Costal cartilage, auricular cartilage, materials for teeth and silica gel have been widely applied in rhinoplasty, but consequent adverse events, such as rejection, prosthesis displacement and implanted skin redness make the outcomes far from satisfaction.OBJECTIVE: To explore the effect of expanded polytetrafluoroethylene prosthesis for lower dorsum with small nasal septum.METHODS/DESIGN: This was a prospective, single-central, randomized, and open-label study that finished in the Qinghai University Affiliated Hospital, China. 100 patients hospitalized in the Department of Otorhinolaryngology for rhinoplasty between January 2014 and June 2015 were enrolled, and randomized into experimental and control groups(n=50 per group). The experimental group was subjected to the polytetrafluoroethylene prosthesis implantation, while the control group received the silica gel implantation. All patients were followed up for 12 months. The primary outcome measure was the postoperative satisfaction at 12 months. The secondary outcome measures were the changes of the nasal internal structure indexes, ultrasonic results of the nasal internal soft tissues and the incidence of adverse events. This study was approved by the Ethics Committee of the Qinghai University Affiliated Hospital and in accordance with the Declaration of Helsinki, formulated by the World Medical Association. All participants had signed the informed consents prior to participation in the study. DISCUSSION: Polytetrafluoroethylene prosthesis and silica gel both exhibit high biosafety in rhinoplasty. Compared with silica gel, the polytetrafluoroethylene prosthesis can effectively adjust the nasal appearance mini-invasively and obtain satisfactory outcomes; therefore, it is expected to be a substitute of filling materials applied in nasal plastic surgery,
关 键 词:聚四氟乙烯 生物相容性材料 随机对照试验 生物材料 材料相容性 膨体聚四氟乙烯 隆鼻整形术 生物相容性 固体硅胶 临床试验 不良反应 组织填充 植入物 塑型效果 超声检查 组织工程
分 类 号:R318[医药卫生—生物医学工程;医药卫生—基础医学]
膨体聚四氟乙烯假体隆鼻整形的效果:随机对照临床试验方案.rar
973.71 KB, 下载次数: 0
售价: 2 氟币  [记录]  [购买]
GMT+8, 2026-10-5 02:58 , Processed in 0.030434 second(s), 9 queries , Redis On.
