查看: 2167|回复: 0
聚四氟乙烯生产过程重大风险研究
发表于 2018-9-28 19:14:45 |江苏| 显示全部楼层 |阅读模式
聚四氟乙烯生产过程重大风险研究
Study on the Significant Risk of Teflon Production
作  者:曹钧
Cao Jun(Jiangsu Institute of Safety Production Science, Jiangsu, Nanjing, 210042)
机构地区:江苏省安全生产科学研究院,江苏南京210042
出  处:《安全.健康和环境》2017年第6期40-43,共4页
Safety Environment Health
摘  要:基于现场调查对聚四氟乙烯生产的风险进行分析,通过危险度评价得出主要生产设备的危险度;应用道化学火灾爆炸危险指数方法对具有重大风险的聚合釜和进料罐进行分析,分别得出采取安全措施前后的火灾爆炸危险指数。研究表明,聚合釜和进料罐的固有火灾爆炸危险分别为“非常大”和“很大”,进行安全措施补偿之后火灾爆炸危险均降至可接受水平。针对重大风险提出的建议对促进聚四氟乙烯的安全生产具有参考价值。
Based on the field investigation, the risk of the production of polytetrafluoroethylene was analyzed, and the risk of the main production equipment was obtained through the risk evaluation. The chemical fire and explosion hazard index method was used to analyze the polymer reactor and the feed tank with significant risk and respectively, taking safety measures to take the fire and explosion risk index before and after. The study shows that the inherent risk of fire and explosion of the polymerizer and the feed tank is "very large" and "large", and the fire and explosion hazard is reduced to an acceptable level after the safety measures are compensated. Suggestions for significant risks are of big value to promote the safe production of polytetrafluoroethylene.
关 键 词:聚四氟乙烯 四氟乙烯 火灾爆炸 危险指数 危险度评价
分 类 号:X924[环境科学与工程—安全科学]
聚四氟乙烯生产过程重大风险研究.rar
1.19 MB, 下载次数: 0
售价: 4 氟币  [记录]  [购买]
聚四氟乙烯生产过程重大风险研究
GMT+8, 2026-8-6 05:13 , Processed in 0.083449 second(s), 10 queries , Redis On.
