查看: 7653|回复: 0
[供应氟塑] Supply PTFE high-voltage insulator【供应聚四氟乙烯高压绝缘子】
 火.. [复制链接]
发表于 2008-7-23 21:00:05 |江苏| 显示全部楼层 |阅读模式
PTFE绝缘子特性:
PTFE绝缘子具有优良的耐化学腐蚀性能, 耐强酸、强碱,耐有机溶剂, 具有极强的抗氧化性能,强介电性能、耐候性能,不燃不粘,极低的磨擦系数,较广的使用温度范围,能在-180~+260度的温度下使用,压强0.1~6.4Mpa(全负压至64kgf/cm2) 。
产品用途:
广泛应用于电子通讯,中高端RF(射频)等系列连接器,化工,机械,电镀,食品, 汽车领域等,是现代工业最重要的绝缘部件。
产品技术参数:
根据您的图纸或要求定制。
产品价格:
根据您的图纸或要求,面议价格。
产品实物图片:
扬中市驰宇塑胶有限公司、扬中市青华机电制造有限公司
业务联络方式:
手机(Phone):013705299665(何先生)
传真(fax):86-0511-88323964
E-mail:qinghua665@163.com
English:
PTFE Insulator properties:
PTFE has an excellent insulator of chemical corrosion-resistant, resistant to strong acid and alkali resistance, organic solvents, is extremely anti-oxidation performance, strong dielectric properties, weathering performance, Noncombustible non-stick, low friction coefficient, a wider use Temperature range from -180 to +260 degrees the temperature use, pressure 0.1 ~ 6.4 Mpa (full vacuum to 64 kgf/cm2).
Product Use:
Widely used in electronic communications, in the high-end RF (radio frequency) series connector, chemicals, machinery, electroplating, food, automobile and other fields, modern industry is the most important parts of the insulation.
Products parameters:
Based on your drawings or require customization.
Price:
Based on your drawings or request, Price to be negotiated in person.
Physical product picture:
Yangzhong City, Jiangsu Province Chi-Yu Plastic Co., Ltd.
Business Contact:
Phone:013705299665(Mr. HO)
fax:86-0511-88323964
GMT+8, 2026-11-27 16:16 , Processed in 1.426155 second(s), 8 queries , Redis On.
