查看: 3381|回复: 0
铝/改性氟塑料复合薄膜的制备
发表于 2010-3-2 19:37:46 |江苏| 显示全部楼层 |阅读模式
 Abstract Aluminum film was grown on modified fluorinated polymer composite films by rf magnetron sputtering. Surface morphology and
composition of the A1 film were characterized with field emission scanning electron microscopy (FESEM) and energy dispersive spectroscopy
(EDS) to optimize A1 film growth conditions. The results show that the sputtering power significantly affects the compactness of the A1 film.
Low sputtering power results in less compact A1 film and weak interfacial adhesion ,whereas high sputtering power overheats and considerably
bends the composite films.We found that sputtering pressure and sputtering time determine the deposition rate and thickness of the A1 film ,re2
spectively.
  Keywords  Modified fluorinated polymer ,Magnetron sputtering ,Surface treatment ,Composed thin film
  摘要 采用射频磁控溅射技术在改性氟塑料表面沉积铝层,制备了金属/ 氟化高聚物复合薄膜。利用场发射扫描电镜
(FESEM) 及能量散射谱(EDS) 分析仪对沉积的铝层进行了表面形貌的表征和化学组分的分析。初步探讨了溅射功率、气压和
时间等不同溅射参数对铝层结构和铝层在氟塑料表面附着情况的影响。结果表明:溅射功率是决定复合薄膜质量的重要因
素,功率过低得不到致密的铝层结构,而且铝层容易从氟塑料表面脱离,功率过高则会产生很强的热效应而使复合薄膜弯曲。
溅射气压和时间分别影响铝层在氟塑料表面的沉积速率和生长厚度。
关键词 改性氟塑料 磁控溅射 表面处理 复合薄膜
铝_改性氟塑料复合薄膜的制备.pdf
641.13 KB, 下载次数: 0
售价: 2 氟币  [记录]  [购买]
GMT+8, 2026-7-15 00:54 , Processed in 0.742541 second(s), 9 queries , Redis On.
