查看: 3588|回复: 0
国外FEP标准
发表于 2026-3-1 19:19:40 |江苏| 显示全部楼层 |阅读模式
标准号 标准名称 英文名称
ASTM D2116-07(2012) FEP——碳氟化合物模压和挤出材料规范 Standard Specification for FEP-Fluorocarbon Molding and Extrusion Materials
ASTM D3368-04(2010) FEP碳氟化合物树脂薄板和薄膜 FEP Fluorocarbon Resin Sheet and Film (08.03)
ASTM D 3296-2003 FEP-碳氟化合物管的标准规范 Standard Specification for FEP-Fluorocarbon Tube
NF C26-145-3-7-1998 电气用塑料膜规范.第3部分:个体材料规范.第7章:电气绝缘用FEP膜的要求 (Specification for plastic films for electrical purposes. Part 3 : specifications for individual materials. Sheet 7 : requirements for fluoroethylene-propylene (FEP) films used for electrical insulation.)
NF C93-540-2-30-2002 通信电缆.第2-30部分:一般设计规则和制造.四氟乙烯和六氟乙烯共聚物(FEP)绝缘和铠装 (Communication cables - Part 2-30 : common design rules and construction - Poly(tetrafluoroethylene-Hexafluoropropylene) (FEP) insulation and sheathing.)
EN 50290-2-30-2002 通信电缆 第2-30部分:通用的设计原理及结构 聚(四氟乙烯-六氟烯)(FEP)绝缘及包复物 Communication cables - Part 2-30: Common design rules and construction; Poly(tetrafluoroethylene-hexafluoropropylene) (FEP) insulation and sheathing / Note: Applies only in conjunction with EN 50290-2-20
ANSI/ASTM D3296-1998 FEP碳氟化合物管规范(08.03) Specification for FEP-Fluorocarbon Tubing (08.03)
ANSI/NEMA HP4-2000 KT型(250V)、K型(600V)和KK型(1000V)电和电子FEP(氟乙烯丙烯)绝缘高温架空电线 Electrical and Electronic FEP (Fluorinated Ethylene Propylene)-Insulated High Temperature Hook-Up Wire, Types KT (250 Volt), K (600 Volt) and KK (1000 Volt)
BS EN 60674-3-7-1995 电气用塑料薄膜规格.专用材料的规格.电气绝缘用氟乙烯-丙烯薄膜的要求 Specification for plastic films for electrical purposes - Specifications for individual materials - Requirements for fluoroethylene-propylene (FEP) films used for electrical insulation
BS EN 50290-2-30-2002 通信电缆.通用设计规则和制造.聚四氟乙烯 - 聚六氟丙烯(FEP)绝缘和铠装化合物 Communication cables - Common design rules and construction - Poly(tetrafluoroethylene-hexafluoropropylene) (FEP) insulation and sheathing
DIN EN 50290-2-30-2002 通信电缆.第2-30部分:通用设计规则和结构.聚四氟乙烯-六氟丙烯(FEP)绝缘材料和护套; 德文版本 EN 50290-2-3 Communication cables - Part 2-30: Common design rules and construction; Poly(tetrafluoroethylene-hexafluoropropylene) (FEP) insulation and sheathing; German version EN 50290-2-30:2002
IEC 60674-3-7-1992 电工用塑料薄膜规范 第3部分:单项材料规范 活页7:对电气绝缘用氟乙烯-丙烯(FEP)薄膜要求 Specification for plastic films for electrical purposes; part 3: specifications for individual materials; sheet 7: requirements for fluoroethylene-propylene (FEP) films used for electrical insulation
GMT+8, 2026-10-5 00:50 , Processed in 0.197436 second(s), 5 queries , Redis On.
