查看: 7561|回复: 0
[应用分享] 特氟龙制品不粘性和耐温性于纺织、造纸工业中的应用
发表于 2008-8-1 23:05:41 |江苏| 显示全部楼层 |阅读模式
特氟龙制品不粘性和耐温性于纺织、造纸工业中的应用【Teflon products do not viscous and temperature of the textile and paper industry in the application】
经过特氟龙涂装后具有很强的不粘性和耐温性,在纺织、造纸行业得到广泛的应用。【After the Teflon coating is highly viscous and not temperature, in the textile, paper making industry by a wide range of applications.】
纺织滚轮表面防粘使用特氟龙【Textile wheel surface Fangnian the use of Teflon】
造纸滚轮表面耐磨使用特氟龙【Paper use of Teflon wheel wear-resistant surface】
GMT+8, 2026-8-9 04:04 , Processed in 0.021011 second(s), 10 queries , Redis On.
